Full OBD Scan tool and FCA Security Bypass Question
gregg3g
CT
2018 Wrangler JLU Sport S
Hands down, best combo for the money is bypass Cable and OBDJscan app - if you want to change Wrangler options.
For just clearing codes - planty of free apps.
Bypass $24
https://www.amazon.com/dp/B07S91VZXT/ref=cm_sw_r_cp_apa_fabc_LvG.FbNGFP9R3
OBD2 bluetooth $30
https://www.amazon.com/dp/B06XGB4873/ref=cm_sw_r_cp_apa_fabc_cyG.Fb6ZGZBB9?_encoding=UTF8&psc=1
Thank you for the great advice. I am a total newb to this so just to be clear what would I need just to identify codes and clear them if needed? I am fine buying both of the above if needed. Which free app do you like? Thank you!
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@gregg3g
If all you want to do is "identify codes and clear them" , all you really need is an inexpensive OBDII Scan Tool that plugs directly into the OBDll port on your JL.
You do not need a Security Gateway Bypass or an App or anything else to identify codes and clear them .... just an inexpensive OBDII Scan Tool.
Here is one that would do the deed for you but there are other's that are even less expensive then this unit..
https://www.amazon.com/gp/product/B072JF8VZF/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
gregg3g
CT
@gregg3g
Great and thank you. I guess I am confused since my mechanic had a couple expensive ones that wouldn’t clear the codes yesterday but then an older cheaper Actron brand one was able to clear them.
I guess it woulld make sense to spend a few more dollars to have more options if needed im the Future.
gregg3g
CT
As I am learning more about this thanks to your comments I think I just need a cheap scan tool. Rhinebeck01 suggested one. Do you have any suggestions for a budget friendly one that works well for the JL that can read and clear? Thank you.
SD70ACEJM
Josh
Kansas
2019 Jeep Wrangler Sport
Bypass $24
I hope this helps those looking for answers, I bought this cable and it helped me clear my stored codes and get rid of my check engine light. My Jeep wouldn't start, just kept cranking, turns out it was a bad fuel pump relay.
