Front Sway Bar Mount
avidangler
Nick
2018 JLU Sport 2.0t
Hello everyone,
I'm hoping to get some insight here on my sway bar situation.
I have a Dana m210 axle that no longer has the front sway bar mount, on the passenger side next to the track bar bracket, I've been looking all over to find a replacement and can't seem to find one. My current thoughts are to either:
1. Try the rubicon express sway bar mounts for the JK (https://www.quadratec.com/p/rubicon...5FauW9HRmh1j0Z51xuceVDJ7Y4KkBGiIaAqpOEALw_wcB)
2. Run it with the sway bar link mounted to the outside of the track bar bracket only. The driver side is only on mounted on one side so I'm thinking it could be ok but at the same time I assume that the sway bar mount on the passenger side was to add more strength to the track bar bracket itself.
Any help would be appreciated!
azwjowner
Phoenix
Did someone cut off the mount to install the JKS quicker disconnects? If so, just install a set of those.
avidangler
Nick
2018 JLU Sport 2.0t
No, it had a bad weld and broke off so it was warrantied out and I bought it from one of the techs.
The quick disconnects are a great solution! Thanks for that.
azwjowner
Phoenix
Yeah, they sound perfect for you since you cut that tab off anyway to install them.
