FOX Steering Stabilizer - Orientation
sstuner
Ray
Northern Virginia
2018 Jeep JL Sahara
2018 JLUS w/Mopar lift. Just installed Synergy Steering Kit (Drag Link/Tie Rod/Stabilizer Clamp). When replacing the OEM steering stabilizer with the Fox unit, does the body of the shock or does the shaft end go on the stud of the axle?
Roky
Roky
Shaft on axle end for me for added clearance when turning…….
Closed end shock…….
Jeep Wrangler JL FOX Steering Stabilizer - Orientation 4CA874A7-B186-4063-AAC5-AE6649F61922
thru shaft….
Jeep Wrangler JL FOX Steering Stabilizer - Orientation 66270294-365C-484E-BB78-E0BFF418EC87
dpike
New Jersey
'20 JLUR 3.6
<snip>
thru shaft….
i had clearance issues with the fox thrushaft with my steersmarts kit, i finally bailed on it and just got a piston one but still bump the draglink and/or trackbar with the stabilizer bracket. i just lifted the jeep 2-1/2" so that should have made a little room since i was sagged an inch and a half or so because of gear weight.
(edit for pic)
prelift..
Jeep Wrangler JL FOX Steering Stabilizer - Orientation oRaguxB
ALRUI
Arnold
Murphy, NC
2018 JLU Sahara, 2003 F150 S-Crew FX4, Others
Unlike the OEM unit I don't see any orientation marked on the Fox stabilizer body so I'm "assuming" it doesn't matter on these?
