For Old Eyes
Hairy.Situation2018
2018 JLU Sahara
I am running a 2018 JLU Sahara. I have factory halogen head lamps. I actually prefer them... in some ways. The main reason is if it stops working, I can replace it without spending nearly $1000. I like to keep things simple. My issue is I'm getting older, and my vision driving at night has been better. I struggle with the on coming LED headlights. They wash out the halogens in my jeep.
I would like to keep the lamps replaceable, but I need to be able to get more output down the road... without blinding other drivers. I really like the amber off-road lights I have because they do not reflect back and cause me issues like the bright white lights do. But, I can't go down the road with those on... I am sure it would be equivalent to driving into the sun for oncoming traffic.
I am looking for a dual beam lamp (HI/LO), amber color if possible and legal, can be LED (I do have concerns with ice build up on the lens during winter weather.)
Any Suggestions? Anyone else in the same situation?
Bulletbill
Tom
Central PA
2021 JLUR
Honestly, I’d go with the stock LED headlights. They are “night and day” better than the stock halogens and you don’t have to worry about the legality of them.
As far as replacing them down the road, I haven’t seen any posts on them failing.
Otherwise, @ORACLE Terry can probably help you out with aftermarket options.
Hairy.Situation2018
Hairy.Situation2018
2018 JLU Sahara
Those things expensive for lighting.
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
yup, not what i am looking for. thanks
I realize that, but your argument for justifying not having LED headlights is irrelevant given that they don’t fail.
But to actually try to help with your problem, I’d start with replacing the halogen bulb for led bulbs. Cheap and worth a try.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
@Hairy.Situation2018
I had the same problem with night time vision/driving after multiple eye surgeries. I installed Lasfit replaceable LEDs in the halogen housing. This was very easy and inexpensive about $50-$60. I dialed them down 2 full turns since then I've never been flashed one time. I can see much better. My local law enforcement said they were fine and it passes state inspection. As far as the snow building up and not melting, yes that could pose a problem.
Best of luck.
https://www.lasfit.com/?msclkid=ee51f6a8b1d11a9678a0912a3f580026
Hairy.Situation2018
Hairy.Situation2018
2018 JLU Sahara
Any suggestions on brands?
Hairy.Situation2018
Hairy.Situation2018
2018 JLU Sahara
Best of luck.
Thank you, Do you know of anything Amber color vs. bright white?
Flip
Johnny
Virginia
I don't know a lot about the amber vs the white. I had watched a few videos on it awhile back, if I remember correctly the big difference was the amber did better in dense fog. To my eyes my factory foglights were basically useless. I installed Lasfit foggers (white) and they're great! A huge difference from factory. I have never been flashed with low beams and foggers on. I have just enough vision to legally drive, until they can figure out whats going on anyways. LEDs have helped me a lot.
Hairy.Situation2018
Hairy.Situation2018
2018 JLU Sahara
Anti-glare with blue light filters in the glasses I got for night driving help a little.
Flip
Johnny
Virginia
I had 2 major surgeries in my right eye. They did manage to keep it from going completely dark but IMO it failed. The vision in my right eye is garbage! Now I'm seeing another specialist, I'm facing at least one more surgery maybe 2 more.
Hairy.Situation2018
Hairy.Situation2018
2018 JLU Sahara
I had 2 major surgeries in my right eye. They did manage to keep it from going completely dark but IMO it failed. The vision in my right eye is garbage! Now I'm seeing another specialist, I'm facing at least one more sugery maybe 2 more.
Well I pray for the best outcome for you.
