Fog Light wiring connector?
JayV908
Juan
Union NJ
Wrangler unlimited
Wait, so you have the bar wired to the factory fog light button? And it works no power isssues or anything? I’ve got the same bumper as you ready to be installed, trying to sort out the led situation before I install. And deciding if I want the skid plate now or later.
I forgot also to mention is you decide to go with the skid plate to install it you will have to remove the bumper completely if you installed it first. The fog light harness has 3 wires the black is ground and the two other wires are separate powers. If you pick any one of the two its fine. They are both the same.
Yakpimp
Moderator
Moderator
K
PNW
Where can I pick up this wire closer to the fuse box? I am adding some cube lights to the A-pillar and want to use the existing fog light switch. The connector behind the bumper would work, but it's pretty far away and I'd rather have the connector up in the engine bay rather than in the bumper.
Anyone know?
EASaharaUJL
Earl
Cumming, GA
2018 Wrangler Sahara Unlimited JL
It looks like it might be wrapped together with the sway bar disconnect wires or something so I can't seem to just yank it out.
I'm checking out https://www.jlwranglerforums.com/forum/threads/jeep-jl-wrangler-wiring-diagrams.19185/ this list to try to find more info.
So I followed up on that link and traced down the following parts listed here:
https://www.jlwranglerforums.com/JL-Wiring-Diagrams/FRONT-FOG-LIGHT-connector-inline-details.pdf
Male Connector:
https://connectors-catalog.sys.yzk....t_e?forward=7282-5570-10&plist=list&select=XX
https://nexelec.com/YAZAKI-7282557010/
Female Connector:
https://connectors-catalog.sys.yzk....t_e?forward=7283-5570-10&plist=list&select=XX
https://nexelec.com/YAZAKI-7283557010/
With this, you can save some $$ instead of purchasing the full wiring harness like some of us did. Hope this helps!
xtopherm
Boston, MA
HellaYella 2019 JLUR
So I removed my steel bumpers with factory fogs and installed a JCR Offroad bumper with LED cubes. I want to wire the cubes to the fogs wiring harness, so that the factory switch controls the LED cubes.
When I disconnected the bumper and fog light wiring from the vehicle, I left dangling the wire harness connector for the fogs. Initially, I planned on cutting it off and splicing in the LED's. Then I got to thinking, if I ever remove the bumper for any reason, I will have a devil of a time unmounting the LED cubes (internal to the bumper) to remove the wiring, why don't I just buy a connector to wire the LED's to, that way I can jsut use the snap connector to disconnect them.
So off to Jeep store I went, only to find that the connector isn't sold separately, but as part of the fogs wiring harness for $50. Here is a pic of the connector in question. Does anyone have any ideas on where to find a connector like this short of paying $50 for the entire harness?
Glad to hear it is only $50 to replace the whole thing. When I replaced my bumper, I scavenged the OEM factory fog harness to plug into that big connector in your picture, but my upgraded fogs had incompatible plugs at the other end of the harness. So I just cut the plugs off and spliced into the ends of the OEM harness. Glad to know I can always reverse that if I need to for $50...
Yakpimp
Moderator
Moderator
K
PNW
I actually have both sides, but since I want to wire the lights on my a-pillar I need to move the one from the bumper up to the engine bay. Has anyone been able to pull the wire up?
Bocephus1963
Ceres, Ca.
2018 JLU Rubicon. 1976 K5 Blazer. 1995 S10 Blazer 4wd
Forklift Operator
Does anyone on here happen to have pics that show the differences between the factory Rubicon LED fog lights and standard OEM or Sahara LED foglights? Wanting to put a front bumper on and they all say they accept OEM LED fogs but then they say they dont fit Rubicon LED's.
Mecha
Eric
WA
2018 Rubicon
From a 2018 JLUR with LED package. Took them off my steel bumper when I upgraded bumpers now they wont fit regardless what DV* says about accepting factory Fogs.
DocLogan
San Antonio texas
2018 JL and 1964 beetle
I’m looking into wiring a small 10” lightbar into my fog lights so I can use my factory fog light switch to turn both on at once. Has anyone done this or have any tips?
JeepTime
Justin
2019 JLU Rubicon
I can't seem to find the part on the mopar store 68336460-AC. Anyone have an updated part number for it? Also is that the part for the LED fogs, is it any different? And lastly, how difficult is this portion of the fog light wiring harness to replace if one wanted to replace it down the line?
The4x4Guys
Bob
Parker, TX
2018 Jeep Wrangler (JL) Unlimited Rubicon
When I sold my steel bumpers and fog lights with it, I left the wiring harness intact in the bumper. When I installed my JCR Offroad bumper with two LED cubes, I decided that I wanted them to work off the the stock switch for the fogs and I wanted them to attach to the factory wiring connector the way the factory fogs had (I'm the original poster of this thread, you can go back and see a pic of the connector I was trying to match up to.
In the end I had to go to a dealer and buy the entire wiring harness for the fog lights to harvest the wiring connector. While I don't have the part number anymore, it was not something that could be bought through the consumer Mopar store, hence the dealer order. When I needed it, there were one or two in the country, since the JL series was still new at the time.
5280Sapper
Saratoga Springs, Utah
2018 JLU Rubicon
Disabled Veteran
Steel and plastic bumpers have different lights! the mounting is different.
Briana
Conroe, TX
2019 JLU Moab
I'm having the exact same issue with my DV8 bumper, did you find a solution? I'm trying to figure out whether a bracket will work or not.
