WranglerMan
- Will
- May 8, 2018
- Greenfield Indiana
- 2018 Wrangler JLU Sahara
- Occupation
- Retired
- Vehicle Showcase
- 1
Not sure if this is the right place to post but have a battery FOB question.
I started having trouble with my remote start but this was related to my main batteries being bad, they charged ok but had low CCA’s and resistance and was advised old or possible cell shorage but that's another story and just replaced both and all seems to work good so on to my main question.
I got in my jeep today and remote start worked fine several times I used it today and at a good distance but I got out to pump some gas and left it running as its cold here and momma don't want to sit in a cold vehicle but when I got back in it said FOB not detected but I shut it off and tried to restart and it said FOB not detected so I had to push FOB against the push-button and message went away.
I had this issue before I replaced the main batteries along with the remote start but that's working fine now, I checked the FOB battery voltage and its right at 3 volts %(3.01 volts) so I cleaned the contacts and put the battery back in and remote started and it worked so I got in and pushed the button and got out with the FOB and did some checks with having it close and in the house and it worked like its supposed so should I replace the battery anyway.
Just looking for some advice
