"FLEX"/Articulation pictures?
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Jeep Wrangler JL "FLEX"/Articulation pictures? 20200831_111107
Jeep Wrangler JL "FLEX"/Articulation pictures? 20200831_111402
Jeep Wrangler JL "FLEX"/Articulation pictures? 20200831_104158
Jeep Wrangler JL "FLEX"/Articulation pictures? 20200831_110905
The front sway links weren't extended long enough and the rear pinch seam was digging into the tires, so both were hampering full flex. I think I can easily get another at least 4" of wheel lift after those hangups are addressed.
i0iin65
Richard
Georgia
18 JLUR, 06 Honda VFR800
I recognize that area! that is under the railroad bridge at NEMO tunnel. Did you climb the hill behind you? If you are fairly close we should go wheelin sometime.
I didn't, but a guy I was with did.
Jeep Wrangler JL "FLEX"/Articulation pictures? DSC_5909.JPG
We're down in Atlanta. We came up to Windrock for the weekend. I'll hit you up next time we're heading that way.
OnlyOne
Northwestern New Mexico
2021 Sport S Diesel on 37s
Good as I can do without coil overs , RK XFactor with Fox socks, ramp is 42” tall........ :)
Dammit that’s a flexy mofo! Another reason coil overs aren’t needed in a JL. Don’t get me wrong, coil overs are badass and flex a tiny bit more, but Not worth the headache. These pics are proof positive. Colby takes good pics!
Roky
Roky
Thanks brother....... I’m really impressed with these shocks. They are expensive, but cheaper than coil overs. They definitely are as advertised.
I flexed the front end to see how far I could droop it before the spring got loose in the housing. I determined that I could go with the shocks for 4.5”- 6” lift, which has extended length in front of 30.5” and 32” in the rear.
I had to adjust my end links and adjust length of locker wire, diff breather hose etc.... took me and Colby a minute and several trips on the ramp to sort out how much bump to run , but I think I’ve got it where I want it, at least for now, lol.
Jeep Wrangler JL "FLEX"/Articulation pictures? C2818DFD-A398-402B-A47E-B57AC4F6BB25
Sweetwater-JL
Thomas
Sweetwater TN
2019 JLU-R
I mean the hill behind your buddy... lol it is fairly steep and about the only difficult part out there. But yeah... shout at me next time you all come up.
Bryce
Bryce
Acworth, GA
2019 JLUR
Put mine up on the ramp at the Mud4Blood blood drive again this year. Kind of surprised that my JLUR with only a 3/4" spacer lift and different wheels went 69.5" up a 30° ramp vs a bone stock JLUR right behind me getting 65" up.
Jeep Wrangler JL "FLEX"/Articulation pictures? 20210417_130236
Jeep Wrangler JL "FLEX"/Articulation pictures? 20210417_130258
Jeep Wrangler JL "FLEX"/Articulation pictures? received_464139568259576
Jeep Wrangler JL "FLEX"/Articulation pictures? IMG_4848
