First time wheeling in UT question. And jeeping out west!
crux360a
Kristen
Indiana
2022 JLUR
Towing and auto repair
I've spent about a year building my Jeep ourselves and am finally headed out west. My husband and I are traveling from northern Indiana and are stopping in CO to meet up with his mom and her boyfriend to do some wheeling. They have done and are taking us to do Oray, Imogene and Ophir knowing that they are pretty simple ones. They have a pretty stock Jeep and have done those trails. Here is my question, we want to try Fins and things and poison spider. But they won’t go into Utah being pretty stock. I have watched countless of YT videos of poison spider and fins and things. But since this is our first trip wheeling are those two BOH trails okay for semi beginners doing it alone. We have done some ATV stuff and my husband is really knowledgeable about jeeping and how gravity/math works lol. I know things look way different in YT video then actually doing it. Didn’t know if there were obstacles that you have to do or you can choose to go around.
Thank you!
Edit:
We leave Indiana July 11th.. will be in CO july 13-17 and will be in Utah july 18-21, from there we will go to Monument Ridge Wyoming 22-23 then travel back home..
SO if anybody is around Moab july 19-21 and want to do some jeeping at l fins and things and poison spider let me know :) Not sure I'm ready for hells revenge.
Attached is a picture with our current set up.
Jeep Wrangler JL First time wheeling in UT question. And jeeping out west! IMG_8882
Johnny B
PA
2021 JLU Sahara
Yeah, from where I'm sitting, that's a seriously stout looking Rubi... Just make sure you have communications if you're hitting ANY trails alone. Cell phones can be often spotty, same with GMRS and CB's. But, if you have options, you lessen the chance of getting stuck in the great wide open outdoors. Good luck, and have a blast!!
crux360a
crux360a
Kristen
Indiana
2022 JLUR
we have a bunch of recovery gear just encase.. I'm not to worried about my jeep making it as much as how tough the trails are.. videos don't do that justice.. we do a lot of mountain biking and the YT video always make it look so simple
Old Jeeper
Don
US Army Infantry, IT Engineer
Thank you!
You are doing RIGHT. Moab is a Jeepers dream. In Moab you have trials that run form 1 - 10
Have fun!
https://www.rr4w.com/ratings.cfm
Trail Ratings
Jeep Wrangler JL First time wheeling in UT question. And jeeping out west! rating01
County dirt road maintained for high clearance 2WD and 4WD use in adverse conditions.
Jeep Wrangler JL First time wheeling in UT question. And jeeping out west! rating02
County dirt road with infrequent or light maintenance after rain or snow, high clearance light duty 4WD required.
Jeep Wrangler JL First time wheeling in UT question. And jeeping out west! rating03
Trail consisting of loose rocks, dirt, and sand with some slickrock surfaces, mud holes possible, no steps higher than 12". 4WD is required, (33") tires are a plus.
Jeep Wrangler JL First time wheeling in UT question. And jeeping out west! rating04
Trail consisting of loose rocks, dirt, and sand with some slickrock surfaces. Some erosion, washes, gulches and rock steps no higher than 18”. 4WD and 33" tires required, (35" tires a plus). Enhanced suspension travel and good ground clearance are helpful. Good driving skills a plus.
Jeep Wrangler JL First time wheeling in UT question. And jeeping out west! rating05
Trail surfaces are rutted, rocky and sandy with steps not exceeding 24”, with considerable slickrock surfaces. Water not exceeding 12” with some mud possible. Good ground clearance and driving skills. 4WD, 33" tires and working traction adding devises (locker, limited slip) are required. (35"tires are a plus). Above average driving skills are desirable. A winch would be a plus. Enhanced suspension travel and good ground clearance are also required.
Jeep Wrangler JL First time wheeling in UT question. And jeeping out west! rating06
Trails are difficult with considerable erosion damage, loose rocks, dirt, and slickrock. Water in excess of 12” is possible with mud conditions. Steps not exceeding 36”. 4WD, 35" plus tires and two traction adding devices (lockers, limited slips) are required. A winch would be a plus. Enhanced suspension travel and good ground clearance are required. Excellent driving skills are recommended.
Jeep Wrangler JL First time wheeling in UT question. And jeeping out west! rating07
Trail consists of rock, sand and considerable slickrock with many steps exceeding 48”. Steep inclines and declines are prevalent. Enhanced off road equipment is required including locking devices (front & rear), 35" tall tires, maximum vehicle ground clearance, and tow hooks. A winch is desirable. Excellent driving skills are required. Vehicle mechanical or body damage is likely. Roll over possibilities exist.
Jeep Wrangler JL First time wheeling in UT question. And jeeping out west! rating08
Extreme trail similar to #7, except a bit more extreme. Same equipment required as #7 plus 37" tires. A winch is desirable. Excellent driving skills are required. Vehicle mechanical or body damage is likely. Roll over possibilities exist.
Jeep Wrangler JL First time wheeling in UT question. And jeeping out west! rating09
Extreme and beyond. The average well equipped trail rig may have great difficulty in completing this trail. Steps exceeding 60". Steep inclines and declines with off camber sections are prevalent. Enhanced off road equipment is required including working locking devices (front & rear), 37" tall tires (40" tires a plus), maximum vehicle ground clearance, winch, and tow hooks, and a minimum wheelbase 100". Excellent driving skills are required. Vehicle mechanical or body damage is likely. Roll over is very common. Spare parts and tools are recommended.
Jeep Wrangler JL First time wheeling in UT question. And jeeping out west! rating10
Let the carnage begin! Buggy territory. Street driven 4X4’s should not attempt this trail. Modified factory vehicles will not be able to complete this trail.
Johnny B
PA
2021 JLU Sahara
Yeah, you two will have a blast. Just be patient. If you have any doubts on obstacles, an alterative route around it is absolutely acceptable. Just have fun, enjoy every mile, and take a ton of pics and vids to go back and reflect on. A chance to reflect and smile all over again. :)
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
I did Fins and things in stock Rubi with 33's. I can tell you that it was considerably more steep than videos show. That said it was a blast and your jeep will impress. I would not recommend doing the transition between the two sides of Fins and Things. It is really rough and can be by passed. Take the bypass! Enjoy the ride.
jadmt
jeff
montana
Fins and things will be easy and always a lot of people running it. Poison spider has dome difficult sections but if you get past the gate keeper at the start you won’t have any problems.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
The second part is soooo much fun! It has a lot of the feel of Hell's Revenge and shouldn't be skipped unless absolutely necessary.
crux360a
crux360a
Kristen
Indiana
2022 JLUR
Awesome. Thanks for the advice. Yea I’m sure it’s way more steep than it looks. But as we speak i just got my metal cloak skid plates in. Didn’t think they would be in on time. So tomorrow that’s gonna be a day to put it on. That will put a lot of my worries to rest about it rocks.
Jeep Wrangler JL First time wheeling in UT question. And jeeping out west! IMG_8884
crux360a
crux360a
Kristen
Indiana
2022 JLUR
Consider waiting at the trailhead and latching onto someone else that's doing it. Just chat with others while airing down :)
Is that totally acceptable? I haven’t done anything like this before. Didn’t know if that was frown on. We leave next week.
Pareto Offroad
Brandon
Durango, CO
2020 JLUR
Makin’ sawdust
IME, YouTube videos are nearly always dramatised. Almost always easier then they make it look.
jadmt
jeff
montana
Amen. I have watched videos and thought on earth do they make it look so hard when it was not nearly that difficult. I can not think of anything on fins and things that would pose any problems fir a rubi on 35’s. I just got back and did poison spider, f&t, top of the world snd elephant hill and only scraped rear control arm skids a time or two.
Pareto Offroad
Brandon
Durango, CO
2020 JLUR
Makin’ sawdust
Drama = Eyeballs = Advertisers = Algorithm Promotion.
A lot of creators go the path of attention gimmicks rather than providing substantive content to drive views. They’re playing the game that the algorithms reward. Can’t blame’em even though I despise it.
Ratbert
PNW
Software Engineer
You just chat with them at the trailhead. They'll either be welcoming or not. Just avoid the ATV crowd.
