FAD Clunk and easy upgrade.
Status
Not open for further replies.
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
Had my 392 for 4 weeks and have noticed a clunk in the FAD since I picked it up used. I'd pull into the garage and park. When leaving I'd reverse out of the garage and when the front axle loads up I kept hearing a clunk so I set to work. Pulled the stock inspection plate and noticed the stock FAD collar had an excessive amount of slop on the splines. You could feel it rotating quite a bit which would make sense that the collar was twisting a bit on the splines when changing directions. I drained the fluid and cleaned everything up first. Installed new fluid and the clunk still remained. Did some reading on this forum and found a FAD delete/spacer kit from Spicer. The replacement collar is much wider than the stocker so it make sense the rotational click could be reduced. I bought it from @Northridge4x4 and had it a day later. THANKS AGAIN!!
Link:
https://www.northridge4x4.com/part/10045078-dana-spicer-fad-removal-spacer-kit
Ripped out the old part last night and so far the clunk is gone. Easy update to an annoying problem that gives me a little more confidence in that area.
This thread is to add info for others who might have this issue in the future. There are plenty of FAD related knowledge but only a little I could find regarding this replacement kit.
Nice color! ?
Jeep Wrangler JL FAD Clunk and easy upgrade. 20221104_161636
Part number for later.
Jeep Wrangler JL FAD Clunk and easy upgrade. 20221104_161538
New spacer test fit. I tried everything I could to pull those stock pins out with some pliers but they just weren't budging so I had to grind them flat.
Jeep Wrangler JL FAD Clunk and easy upgrade. 20221104_170308
Much more spline engagement. Considerably less twist in the collar now that there is more engaged.
Jeep Wrangler JL FAD Clunk and easy upgrade. 20221104_171958
Shoulda painted my bolts black.?
Jeep Wrangler JL FAD Clunk and easy upgrade. 20221104_175403
stumblinhorse
Inside the FAD cover on a 392 is new territory for me. So quick question, did you pull a front axle shaft to install this? Looks like a good upgrade. Nice work.
Terpsmandan
Penn Yan
Please elaborate. There does not seem to be any instructions available on the interweb. I haven't heard the clunk yet but diesels don't only come with the PT 4x4 t-case.
DOOKEY
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
The FAD cover on the 392 is unique in the JL platform. My 18 and 19 have the functional FAD motors so it still disconnects to provide the FAD function. The 392 FAD cover has a cast "shift" fork that doesn't move. It just holds collar in place to keep the mid shaft and outer shaft locked together.
In order to do this upgrade you have to remove the CV portion only to remove the stock collar and install this beefier unit. So removal of all the parts on the knuckle have to come off as well. Took about an hour with my trusty impact.
DOOKEY
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
Any FAD could develop the clunk. What came in my axle was a bunch of sloppy parts. The collar inner splines were very loose on both stock shaft sides. It happens. The best solution if you want to remove the FAD function is a solid 1 piece inner shaft. Less moving parts means less chance for failure. I'm 95% sure these stock axles won't stay under my Jeep so this fix was a process of elimination and instead of spending the money on replacement shafts I can understand better what's going on with this axle.
firedude
Bret
AZ
2022 Rubicon XR 392 Stingray
Retired firefighter
Thanks for the heads up.
Bronson90
Bronson
Dallas, Texas
www.blacksonbrick.com
‘21 JLU 392 XR
thanks! do they make a full non-fad stock axle for the 392?
DOOKEY
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
Yes. There are replacement 1 piece shafts. Spicer makes a set and so does RCV.
Bronson90
Bronson
Dallas, Texas
‘21 JLU 392 XR
Any chance you have a spicer part number? I can just replace the passenger side or do I have to replace both?
Thanks in advance!
DOOKEY
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
BadA$$Rubi
Bryan
Northeast Ohio
2019 JLU Rubicon
Just to add my 2 cents worth and to my knowledge, the Dana Spicer is NOT a 1-piece passenger axle design. Only RCV offers that design.
Dana Spicer’s kit is designed as a FAD DELETE System that couples the passenger axle to the intermediate axle. The axle kit 10044459 you listed does not include the FAD Removal kit. The FAD Removal Kit: 10045078 can be purchased separately, which includes a splined coupling and other miscellaneous parts.
There is a complete Front Axle Kit 10044474, that includes axles and FAD Removal Kit.
Jeep Wrangler JL FAD Clunk and easy upgrade. 1668424455585
Jtphoto
Thunder Bay ON
Thank you for posting this. Going through the same things but more to get ride of the computerized FAD not engaging my FAD.
Bzinsky
Usa
2022 rubicon 4xe
I thought the 392 does not have a FAD? This is news to me.
it doesn’t have 2wd so what’s the point?
edit:nm I saw the explanation above
DOOKEY
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
Trying to keep the rear axle alive. ?
Status
