Extreme Cold
viper88
Nick
IL
Difference in mpg? Probably the extra time warming up from the remote starts consuming a bit more fuel.
Flyper
Minnesota
19 JLU Rubicon
I reset the mileage after heading out to adjust for that. I think the air was so dense the "brick" had more trouble than usual at speed. It never got warmer than the minus teens until close to home. The wind noise and more than usual shifting out of 8th were typical of driving into a signifiant headwind. I had the cruise set on 70 and have done enough trips to know that no wind mpg at that speed is around 20 and headwind mpg drops to around 16. I was showing 14. I thought maybe I was losing my mind because chimney smoke was going straight up and flags were limp.
Flyper
Minnesota
19 JLU Rubicon
That's it. 14mpg is unacceptable the 1 week a year I road trip it in those conditions. The diesel won't work so I guess I need to get a 392!! It will stay in 8th.
viper88
Nick
IL
Colder temps also means longer periods of cold and thicker viscosity for oil and drive-train oils and fluids.
INCRHULK
Lance
Canada
litwphoto.com
2019 Wrangler Unlimited Sahara (retired), 2021 Gladiator Rubicon Diesel
Program Manager, Information Technology
You burn more fuel keeping the engine at stoichiometric temps, the air is denser and also colder hitting the radiator. I see a considerable drop in range anytime the temperatures drop below about -10C. Almost made me consider swapping my JT grill out and back to stock. I suspect a bit of cardboard covering part of the radiator, or the old fashion radiator blankets would help.
CpT Papa
RUBICON 392
Cold Cold Cold like an ice cream cone here in SoCal. Had a low of 45 this AM but warming up to 72. Should be 80's next week.
INCRHULK
Lance
Canada
litwphoto.com
For reference, it's currently -13C here. I'm averaging 13.5 - 14l/100km
INCRHULK
Lance
Canada
litwphoto.com
viper88
Nick
IL
You would think a properly working thermostat on modern engines is adequate for regulating operating temps.
Hearhear
Lexus, 392 XR Wrangler
Here's my weather forecast in south Florida- 80 today but some very cool nights heading our way-
Jeep Wrangler JL Extreme Cold WEB-7-DAY-forecast
Rescue119
Cory
Trenton, ON, Canada
2021 Jeep Wrangler Willys, 2021 Jeep GC L Limited
I try my best to plug in the block heater anytime it is below -10C/14F since it is parked outside. Around -30C/-22F it sometimes makes a squealing sound on cold startup... no idea what it is but it goes away.
but pretty much the frigid temps just wreck your fuel economy. very common for any vehicle. On very cold days I get around 16.5mpg.
Block heaters dont need to be used unless its less then -20C.
In colder climates they put additives in the gas (winter gas) and it gives you worse mileage.
I ve had no squeaks or any noises up to -35C so far
viper88
Nick
IL
The Midwest where we are is in the corn-belt. Lots of ethanol blends. We have winter gas blend here also. I remember a 10%-15% difference in mpg difference running winter blend.
Rescue119
Cory
Trenton, ON, Canada
and we are at 1.50/liter right now. was 1.10/liter when i picked it up in Oct. ya carbon tax
