Exhaust boominess
agentsmurf
Jon
Vancouver
21’ Diesel Rubicon Sarge Green
Can anyone help with some feedback on the 2024 392 exhaust boominess on deceleration, around 2k, seems specific to the 2024.
In particular, did it go away when changing to a different exhaust, if so which one?
Cant seem to find any conclusive fix, have read all the posts.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I dont know what you mean by exhaust boominess. The exhaust is louder at deceleration, maybe a garble sound perhaps?
Old Dogger
Bill
Cave Creek Arizona
Yes, the Jeep Wrangler Rubicon 392's exhaust has been changed in 2024:
  • Performance H Pipe
    The MRT Street Race H Pipe replaces the stock X pipe and resonator, giving the 392 a deeper tone and more horsepower. The H pipe also allows you to control the sound level with the factory exhaust valve system.
WantToWander
Austin
2023 Rubicon 392
I think the MRT H Pipe is aftermarket and can be installed on any 392 but isn't stock on any of them.
Some of the boominess (drone?) I experienced was from the active noise cancellation. If you disconnect the microphones in the rollbar above the back seat near the speakers (need to remove the plastic trim) it disables ANC.
We just need a way to disable the annoying 4cyl mode and the horrible, augmented sound it makes when in that made...
jgp
agentsmurf
Jon
Vancouver
I deserved that... :)
Ok so I only find it on the 2024, and its a strong resonance when decelerating and hitting 2000rpm, so only in the lowish rev range not above 3000rpm. I know the 2024 has dual pane glass in the front windows, and wondering if this causes it.
Will try the ANC trick, although I have read elsewhere in the forums that it doesn't do anything.
Also going to try the Magnaflow street exhaust., will give feedback on this issue as I know others have experienced this as well.
JLJeepGuy513
Ivan
2018 JL Sport, 2024 Pathfinder Rock Creek
Civil Engineering Designer
Its called awesomeness...stop rubbing it in
Right!!! It's like, " oh no! my jeep sounds awesome! how can i make it sound like all the other jeeps that the peasants drive ?"
grandsrus
DFW, TX/ Melbourne, FL
2019 JLUR
Aerospace
Hello, welcome to small motor Jeep Club...I only have a 6 cyl....i need the 12 step process...lol
agentsmurf
Jon
Vancouver
Have you driven a 2024, all you smart asses with your fancy animated Gifs? There is awesomeness 2021-23, and then there is stupid resonance 2024-, I need this solved, dont mock my boominess.
grandsrus
2019 JLUR
Aerospace
Jeep Wrangler JL Exhaust boominess thou-doth-protest-too-much
