ESS and 8.4 Dash Problems
somedude922
McFrisco
2021 JLUR, Previous: 1984 CJ7, 1979 CJ7
You need to pull codes from your Jeep. There are multiple reasons why ESS will not work. I just went through something similar on my 2021. Turned out the solar sensor was bad. The Jeep has to have a all systems nominal for the ESS to work, not just bad batteries.
Dr3wDrop
Dr3wDrop
Andrew
Columbus, OH
2018 JLU Sahara
Scanner tool says there are no codes. Tried to clear codes anyway and the service stop start light is still on.
Jeep Wrangler JL ESS and 8.4 Dash Problems E5773118-64D3-4104-8B72-5933278940F8
Dr3wDrop
Dr3wDrop
Andrew
Columbus, OH
2018 JLU Sahara
The most annoying thing is when the auto park turns on when i shift from P into R or D.
Dr3wDrop
Dr3wDrop
Andrew
Columbus, OH
2018 JLU Sahara
I have narrowed things down to be a problem with the door. If i unplug the door the Service ESS and autopark light do not come on. Does anyone know of a tutorial how to replace the faulty door latch that i am reading about?
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
Are you sure you do not have a bent terminal in the door wiring harness connector?
Dr3wDrop
Dr3wDrop
Andrew
Columbus, OH
2018 JLU Sahara
I just checked the door pins. All look fine. Even took needle nose pliers and tugged on them to see if any weren't seated correctly.
The door switch lighting works, locks work, exterior handle and interior handle works, mirrors work.
Jeep Wrangler JL ESS and 8.4 Dash Problems 138CF132-245F-45AE-B72D-DB863FDF8F8B
Dr3wDrop
Dr3wDrop
Andrew
Columbus, OH
2018 JLU Sahara
I checked the two hood pressure switches. They both seem operational. I even swapped the tops on them to be sure since I know the pressure switch that shows the hood was left open is working. No change.
Dr3wDrop
Dr3wDrop
Andrew
Columbus, OH
2018 JLU Sahara
Update. Dealer replaced a faulty door latch and everything is working like it should.
Mack.
South West Florida
2018 Wrangler Unlimited Sport LJ
@Dr3wDrop
The batteries are hooked up in parallel.... Keep in mind the old adage.... one bad apple spoils the bunch...
With that said do replace both batteries. You can do quite easily yourself and with very good batteries for about $320.00 +- total. Naah, do not just replace the Aux. battery.
And............ no not crazy at all....... those 2018 OEM batteries have / are aging out... are not healthy.. Many 2018 owner's have seen their batteries age out / become unserviceable.
LOL amazing these cheap shit batteries lasted 3 years!
