Engine stall
CJS
Clem
2018 Jeep Wrangler JL
I have a JL Sport S with an automatic transmission (about a month old from the factory). Last night the engine stalled almost immediately after I started up and put the gear in to the drive (D). When I restarted the engine the gear was stuck in P and wouldn’t go to D. I was able to shift the gear to D eventually after about 20 seconds or so and drive home. But all the while I was driving (about 15 miles) there was a warning light right above the fuel gage (the auto start/stop icon with an exclamation mark). I came home and turned off the engine. When I turned it on again within about a minute, the warning light disappeared. This was the first time it happened. Has anyone experienced anything similar? Hope this was one off event. Should I take it to a dealer for service?
Jeep Wrangler JL Engine stall 7D4C8940-D1C4-4BD7-9209-8A40E2591177
WXman
Central Kentucky
That's an ESS system fault. Start with the simple things like making sure all your fuses are seated properly in the box under the hood.
CJS
CJS
Clem
Thank you!
TaiMc
Tai
Houston, TX
'18 JLU Sport Mojito!, 3.6L & '18 Ninja 400 KRT
Communications Manager
Wow didn't realize the odometer/tach screen looks so different from a Base Sport. Did you get a tech package or is this stock with the Sport S?
CJS
CJS
Clem
As far as I know, I have a “regular” Sport S (I adjusted backlighting). As for my ESS problem, I have checked all my fuses, and they’re fine (nothing lose I could see). I ran an OBD diagnostic, and it listed “DTC P06EF Engine Restart Performance.” I will be taking it to a local dealer to get it serviced. Will post their findings and any repairs done.
Jeepsterfreak
Honda, Future JLU
The cluster display is the same display in both the Sport and Sport S. You have to upgrade to the tech package to get the larger cluster display shown in this thread that is standard on the sahara and rubicon. The tech option is only available on the Sport S. It also includes the larger 7” UConnect 4 center display with apple car play and android auto.
TaiMc
Tai
Houston, TX
Ahh okay, so it is because of the Tech package then?
the_webers_inc
T. J.
North East Iowa
2018 JLU Sport S 6spd, 2011 Subaru Forester X Premium 5spd
That is correct - a Sport S with the Tech package also receives a color display in the instrument cluster, similar to what the Sahara & Rubicons have.
JeepCares
Auburn Hills, MI
JL
Keep us updated on your dealer visit, CJS. If an additional layer of assistance is needed, don't hesitate to connect with us.
Jasmine
Jeep Social Care Specialist
Jeslokin
Gary
So Cal
2018 JLUR (Punk'n)
Ever get closure on this? I have a JLUR with <1,000 miles (same color, btw). Just previous to the issue, I was on cruise control for 45 mins (not sure if related). Exited the freeway at a traffic signal and the whole Jeep jerked - I thought I got hit from behind. All other symptoms are like what you wrote. My VIN is outside the U87 recall band. Looking for answers...
CJS
CJS
Clem
Yes and no. Contacted a Jeep dealer shortly afterward and described the problem. Was told that it would be difficult to find out the cause, if the problem didn’t persist. Also was told something like “it’s a new model and I should give it some time for all the new technology to settle...” which I thought was kind of bogus. I read on this forum to make sure to check the fuse box and secure all of them in place. I did that, and my Jeep hasn’t stalled since (I now have about 4,500 miles on the clock).
Well, having said that my Apple CarPlay just stopped working today (was working fine). CarPlay icon doesn’t even show up. Don’t know if it has anything to do with the fact that I have recently updated my phone to iOS 12...
DToxic
Blake
Bay Area, CA
2018 JL Rubicon
wow can't believe I found this thread!
My '18 Rubicon had the same issue as you described (14k miles). Took it into the dealer and they pulled a P06EF code (Engine Restart Performance, https://www.dtcdecode.com/Jeep/P06EF). They flashed the PCM software and say that's the fix...but I'm not convinced. All the causes per the decoder appear to be mechanical. I have noticed my ESS system taking longer to be "ready" since I first purchased it. I feel the main and or aux batteries are the issue (I have tow package as well).
I'll check my fuses...can't hurt.
