Engine light and ESS trouble
MotoX989
Jarod
Iowa
Jeep JL Sport S Unlimited
My 2018 JLU Sport S throws an engine light and the ESS code, says its code P1404 and U0168. I’ve ran throw checklist and it says it’s an EGR valve. I cannot find anywhere how to service this or where the EGR valve is at to clean it/check it out. Anyone know location or have a video? I’ve poured through the threads here, YouTube, etc. no luck
Also, I just replaced the Aux and main batteries a day ago and no luck after clearing codes. Any help is appreciated..have it parked til I can figure it out.
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
An engine error can cause ESS to be disabled and light the ESS error light. Get your engine error resolved first and see if that turns off the ESS error.
MotoX989
Jarod
Iowa
Any ideas on EGR valve? Cannot find a schematic at all that shows where the EGR is located.
SmartStopStart.com
Peak Sponsor (Level 2)
Arlington, VA
www.smartstopstart.com
2019 Wrangler JL Rubicon Unlimited Sting Gray
Electronics Engineer and Business Owner
It is on the driver's side of the engine. You need to take the engine cover off. Photo shows the EGR valve connector being unplugged.
Jeep Wrangler JL Engine light and ESS trouble JL 3.6 EGR
MotoX989
Jarod
Iowa
Thank you! I’m going to check this out first to see if it’s our culprit. Much appreciated!
MotoX989
Jarod
Iowa
Removed and cleaned EGR valve, double checked fuses, married and unmarried Tazer…still showing permanent code for 1404. Sad..guess it’ll have to end up seeing the dealership.
MotoX989
Jarod
Iowa
It was the EGR valve. I did remove mine and clean it well but it was stuck. Local shop replaced under warranty. Codes cleared and good to go.
