Engine hiccup
El-Jefes-Red-Rubi
Allen
Sparta, Georgia
2022 Sting Gray JTR
Need help figuring this out? My JLUR just started hicupping on a trip to Florida. It’s not a misfire. No real loss of power or momentum. Under hard acceleration it is perfect but on cruise control, 70 mph, I feel a quick hiccup every now and then. Tach looks good; doesn’t jump. No codes. 3.6l auto.
Carolina Jeeper
Rollie
North Carolina
It never hurts to check all of the wiring harness connections underneath the hood. Also do the Jeep JL fuse and relay check to be sure they're fully seated.
Without codes it's mostly just the SWAG method.
j2.pictures
Justin Null
Northern California
www.instagram.com
2021 Wrangler Unlimited Sport S
CDJR Salesperson
Do you notice this if you are driving into the wind?
El-Jefes-Red-Rubi
El-Jefes-Red-Rubi
Allen
Sparta, Georgia
2022 Sting Gray JTR
Wind wasn’t an issue that I recall. Just driving. Stop and go and interstate. When I’m at a constant speed. Hard accelerating is great no problems. Don’t honk wind of environment are either.
jonyothan
Jon
Ontario, Canada
'22 Rubicon 2dr 2.0T, '10 335i, '03 Golf TDI
HD Mechanic
Not sure if this is your issue, but I used to work at a bmw dealership and lots of them would "phantom misfire" do exactly what youre describing and not throw codes. A lot of the times it was spark plugs or ignition coils starting to go bad.. not sure if yours is manual or auto but a way you can check it is manually shift into the highest gear and accelerate as hard as you can at a low speed intentionally lugging the engine.. like 50mph in 8th if its an auto. if that causes the what you are describing and a normal hard acceleration in the proper gear does not then its definitely a phantom misfire and id start with spark plugs
JSPRUBI44
Jason
Georgia
2020 Jeep Wrangler Unlimited Rubicon
Interesting. I came here to post. I started having this issue today. While driving in auto between 7th and 8th gear it feels like a surge about every 10 seconds or so. The rpm’s will jump ever so slightly. When I’m Manual mode it does not happen. I turned the AC off and it stopped. Turn AC back on creates the problem again.
2020 Rubicon JLU
34k miles
Srdjan
Srdjan
Abu Dhabi
Wrangler JL Sport 2 DOOR
Did anyone face the hiccups when the engine is cold and at a low speed?
It is not happening literally every time when it is cold but comes sometimes.
Any Idea what it could be? Really makes me crazy...
JSPRUBI44
Jason
Georgia
FYI: Took my Rubicon to the dealership about the engine surging problem when the AC is on. There was a TSB 18-049-22 that pertains to a misfire condition that is not setting a DTC - PCM software update is available. They updated software. Issue seems resolved for now. Had a 70 degree day here in Georgia and ran the AC on blast. Hopefully this helps some.
powells2000
Ray
Indiana
2018 Jeep Wrangler Sahara
Did you get a resolution? Mine happened yesterday on my ‘18 JLU. I noticed it during 7 & 8 gear. Not on cruise control and not running air conditioner.
speedymart
mephis
2021 jl
What you're describing is a misfire. If it's not bad there won't be a code thrown. You can look at the misfire monitor to determine which cylinder is causing it, or wait until the problem becomes more pronounced and it throws a code.
I've also seen failing crank senses cause exactly the same condition
El-Jefes-Red-Rubi
El-Jefes-Red-Rubi
Allen
Sparta, Georgia
2022 Sting Gray JTR
my issues turned about to be ejectors I believe. Tried Lucas cleaner and it got better. Then Seafoam and it decreased to almost nothing. Just occasionally under strain.
I decided to sell the Rubi due to this and other annoying issues.
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
That sucks. My v6 only ever hiccups once in my 40-mile round-trip commute, and it's always in the exact same spot. Coming from a stoplight turning right onto a steep incline (maybe 30° or better) it almost always seems to hesitate for half a second halfway up that hill, but no where else that I've ever noticed.
Still have low miles and only use mid-grade Top Tier gas, so really doubt it's a misfire or clogged injectors already. It's very weird, whatever it is. Might try some cleaner in my next tank just for the heck of it.
JayboCee
Jason
Danville Illinois
2019 wrangler
I was having a hiccup when driving between 45/60 after acceleration. I did all of the suggestions on here and nothing worked . I filled up my tank and a full bottle seafoam ... Boom no more problems after 2 weeks. Good luck to everyone . I hope u get a easy fix like I did.
JimsRubicon
Jim
Massachusetts
2022 Wrangler Rubicon JLU - Manual, Prem. Soft Top
My 22 Rubicon 3.6 Pentastar has been doing this ever since it was new. In my case... it is much worse on 89, 91 or higher octane gas. It almost never happens on 87 octane so I just use that all of the time and put in a can of the Chevron Techtron Fuel System Cleaner each oil change to clean up the filth the 87 octane is likely causing.
alphawolff
california
2021 JLU
https://www.jlwranglerforums.com/fo...6-jl-3-6-models-bmp-calibrations-tune.164496/
factory tuning issue. the above thread will guide you on how to get it fixed. engineering ignored the issue so Brad decided to fix it himself and now offers the tuning service
