Engine check/malfunction warning light?
GCJCTC2
Greg
2018 Jeep Sport S JLU
My engine warning light came on, manual says could be bad gas, loose gas cap etc. anyone have any solutions/thoughts before I take it to a shop? 2018 JLU 3.6 only 44,500 miles on it
Jeep Wrangler JL Engine check/malfunction warning light? IMG_9659
oldcjguy
Jim
Central FL
16 Challenger Hellcat, 19 Challenger Scatpack, 20 JLUR Recon
Software Engineer
Go to your local AutoZone and they will check it with a scanner for free. They'll also tell you what code tripped the light
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
It could literally be hundreds of things. That just indicates that something threw an error code. You (or someone else) need to get a code reader to see what code was thrown to know what failed.
GCJCTC2
GCJCTC2
Greg
Certainly confirmed with the above suggestions, are you closing that gas cap with at least 3 clicks and is the rubber seal in need of replacement.
..he asks, having 'attended' this school of hard knocks..
Thanks, went to auto zone scan said to replace the Canister Purge Valve. 👍
GCJCTC2
GCJCTC2
Greg
Thanks all, went to AutoZone scan said to replace the Canister Purge Valve. Picked up the part, should be easy swap.
