Emissions
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Not sure about the others, but afaik, the EVAP codes are usually thrown after a failed cycle testing the pressurization of the fuel tank and lines. Having a loose or faulty gas cap can often cause it, as can having holes in your filler neck and fuel lines. If it's nothing obvious and replacing the gas cap doesn't fix it, you'll probably have to take it somewhere that has a fogger machine to pinpoint the location of the leak.
Had that happen on my last car and never could figure it out. Thankfully, it didn't effect the operation of the vehicle and we don't have emission testing in our particular county. And when selling the car, the dealership didn't seem particularly concerned about it.
2nd 392
Ca
Similar on my 4R- first simple attempt at a new cap failed, pressure and fog test failed. Desperately wound the cap like I was winding a clock. Warning lights soon went out, never to return with continued winding ??‍♂
  • Like
Reactions: AFD
AFD
Northeastern US
So you just kept twisting the gas cap as it was clicking? I know a few other people that still have that issue, so definitely worth trying.
I'm kinda wondering if stuff like this is from the metal filler lip getting slightly bent, bumped or deformed by gas pump nozzles and not allowing for a proper seal of the gas cap. Twisting the cap a bunch of times might've just bent it back into shape.
Beachcomber72
2022 JLU High Tide
Are you trying to say your inspection was due yet you had a check engine light so you decided to pull codes? If so what codes did you specifically have?
wcjeep
Earth
YJ with stuff. JL 2dr Sport
Before throwing money at the problem. Check your owners manual and your specific state laws. Sometimes vehicles are required to pass emissions thru certain age and mileage limitations.
2nd 392
Ca
It did not bend anything back, I tested a few clicks, several winds required. Whatever works ??‍♂
Mgdstar
2024 Rubicon X, 2007 & 2008 Sahara Unlimited
I have been battling these codes since July. Replaced two sensors but codes came back two weeks later. Have two more sensors to replace, but have until August when my registration renewal comes up. On 2008 Unlimited with 178,000 miles.
Jeep Wrangler JL Emissions IMG_4689
five9dak
PA
Bikini '20 JL Freedom, '99 Dakota R/T, '11 Boxster
Your cats have failed. with 178k miles, its no surprise.
At Risk Ute
Christian
‘23 392 XR
Retired Navy
Have you tried unhooking the battery and completing draining the system? I could not get my gas light to go off and that’s what fixed it for me.
Mgdstar
I’m afraid that is the problem. I have been told by a mechanic that I would have to buy “California compliant Cat” which are just standard Cats with a CompLiant stamped on it which about doubles the cost. Not sure where the extra money goes, maybe another State tax.
I did try two new gas caps be have not tried twisting the shit out of them. ?
five9dak
PA
Move out of that state.
dsgrey
2019 JLU
Yes, I had the steering gear replaced via the TSB and they pulled the battery 4 weeks before my inspection. I had two not-ready codes after those 4 weeks so it wouldn't pass. I can't recall what I had to do to resolve one but another had some crazy - immediately drive between x and y speeds for 20 minutes which isn't doable. Luckily in my state, you can pass with 1 code in the not-ready state for the year model. I think a 10 or 15yo vehicle could have 2 in the not-ready state. Last year all codes were clear at inspection so that last one cleared somehow during that time.
Bandit59
Tennessee
2021 Jeep Wrangler 4xe
Hey Guys,
So my 2018 JLUR MT honestly has been nothing but issues since I bought it. New transmission at 5k because of complete synchro failure, new rockers and cams, clutch failure at 40k, 4WD service lights. If I didn’t have the lifetime warranty, I would have gotten rid of it by now. So a new problem arose and I really can’t seem to get to the bottom of it and I was wondering if anybody else has this problem. I recently was up for inspection and used my code reader , the HCAT, AIR, EGR, and EVAP refuse to set after numerous drive cycles, nearly 1000 miles, I’m at my wits end and I’m going to take it to dealership once again. Has anybody experience anything similar?
I had a 2021 with a evap problem. They smoked it. They tried to fix it never could find it. They said it’s a warranty issue but could take forever to fix. Have to replace a part at a time. It was time to cut ties
