Jnowe413
21' rubicon ecodiesel with 7,700 miles on it..... A few days ago I moved my jeep in my apartment parking lot (thankfully I wasn't out on the road somewhere) and when I pulled it into a parking space and put the thing in park, the dash started to give me a light show, beeping, every dash light and code that the jeep has came on, interior lights flickering etc.... So I tried to turn the thing off. The engine shut down but all the electronics were still glitching out! The shifter had all lights illuminated (park, reverse, neutral and drive) the dash was ticking and clicking and the rpm and tach needles were jumping. Just a total nightmare. So I disconnected the main battery and pulled it out, then disconnected the aux battery and also pulled that out to finally make the jeep stop. I tested both batteries with a multi meter and the main battery was good 12.8 volts, the aux battery was 6 volts. So i put the aux battery on the charger and got it to 12 volts and 100% charged according to my battery charger. Put the batteries back in and jeep started up! No issues besides the typical "auto start stop fault" after you have a aux battery problem. So I tried to drive it in the parking lot again and voltage dropped so quick and boom the jeep shut down on me in drive and the same exact electrical glitch happened (same stuff with all the flickering of lights, ticking, and clicking). So i had to pull the batteries out AGAIN to make the damn thing stop freaking out. Then popped into neutral and pushed into parking space. Then I went out and got a brand new aux battery. Tried it all over again with new aux battery. The jeep ran much longer this time but I didnt even move the jeep because i just monitored the voltage the whole time which kept dropping. Then boom same exact electrical nightmare. I put the origional aux battery back in and called the dealer. It will get towed to a dealer tomorrow. I will keep the forum updated. But has anyone had this happen?!? Or any ideas what the hell it is??? FYI i checked all the fuses and nothing was blown. Cant really tell with the high amp fuses though sinse they are a weird configuration. Maybe PCM / ECM / ECU or something like that?? maybe it is one of the high amp fuses??
