Rear defrost causing electrical problems
FireAnt21
Tony
Wisconsin
2020 Sahara Unlimited North Edition
Lineman
Good evening jeepers. I’m having an electrical problem hopefully someone can help me figure out. I have installed a few turn signals I added on. They were working fine for a while then I noticed that if I turn on the rear defrost the amber turns on the passenger side illuminate but don’t flash even if the signal is on. Turn off defrost and everything works again. I took things apart isolated each component and each worked fine as long as the defrost was off. Hope any electrical guru can help me out. Just started like a week or two ago haven’t done anything electrical in that time so I’m confused
Beachcomber72
2022 JLU High Tide
To me it’s as if you possibly tapped a switched ground. Or you’re back feeding onto a ground.
FireAnt21
FireAnt21
Tony
Wisconsin
Lineman
Beachcomber72
2022 JLU High Tide
How did you exactly as possibly describable hook up the turn signals?
