- Jeremy
- Oct 3, 2020
- Louisville, KY
- 2020 Jeep Gladiator / 2022 JLUXR
The Driver Side Fender Under Hood ARB Single Compressor Mount is another ARB compressor mount that we offer.
Works with 3.6L & 2.0 Non-eTorque Engines. DOES NOT fit Diesel, 4xe or eTorque engines. Keep in mind, the compressor slightly rubs the hood liner of the Rubicon hood, see photos.
Jeep has made a change under the hood. They are now including the GSPEC5 computer which changes the mounting bracket that the compressor mount was designed to fit. We are working on an update for the side mounting bracket and try to have those available ASAP! Please look at the photos in the description to verify if you have the correct non-GSPEC5 mounting bracket.
Designed to mount the ARB Single Compressor, model CKMA12. Included with the kit are: Compressor mounting plate, side mounting bracket, air coupler, air hose, air fittings and mounting hardware. Optional rocker switch plate also available.
https://www.813fabrication.com/product-page/underhood-arb-single-compressor-mount-jt-jl
