ARB Single Compressor Underhood Firewall Mount
813 Fabrication & Design
Rock Sponsor (Level 1)
Jeremy
Louisville, KY
2020 Jeep Gladiator / 2022 JLUXR
Designed to mount the ARB Single Compressor, model CKMA12.
Included with the kit are: Compressor mounting plate and firewall mounting brace. We also offer an add-on fender air kit which includes air coupler, air hose, air fittings and fender plate for mounting the rocker switch and air coupler on the passenger fender.
The mount is 1/8" powder coated aluminum for superior corrosion resistance. Stainless steel mounting hardware included. No drilling required.
Fits Jeep Gladiator & Jeep JL with 3.6L & 3.6L eTorque Engines. We are currently testing for fitment with the Diesel, 2.0, 4xe and 392 Jeep engines.
https://www.813fabrication.com/product-page/underhood-arb-single-compressor-firewall-mount-jt-jl
Jeep Wrangler JL ARB Single Compressor Underhood Firewall Mount Underhood-Single-Compressor-Firewall-06
Jeep Wrangler JL ARB Single Compressor Underhood Firewall Mount Underhood-Single-Compressor-Firewall-07
Jeep Wrangler JL ARB Single Compressor Underhood Firewall Mount Underhood-Single-Compressor-Firewall-08
Jeep Wrangler JL ARB Single Compressor Underhood Firewall Mount Underhood-Single-Compressor-Firewall-13
Jeremy
Louisville, KY
Did you guys end up testing this with 4xe? Will it work?
I had a customer do some testing with the 2.0 engine, so same setup in that area. It gets very close to the turbo pipes in the firewall location and would be exposed to some extreme heat if mounted in that location. There may be other customers who have done so, but I am unaware if they have. With that much heat concentrated in that area I am not sure I would recommend it. I have a few other mounts for the Wrangler if one of those is something that would work for you. Thanks!
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Really appreciate you being forthright with this.
I currently run an ARB single portable I’d like to hardmount somewhere other than in cab.
Jeremy
Louisville, KY
I saw your website; really cool stuff! I'm looking for an under the hood option. I already have too much crap in the cabin/cargo, and I want it out of the way.
Thanks! Let me know if you have any questions with anything.
Jeremy
Louisville, KY
Always! I try to help customers with the best setup possible. I have the rear gate system, but that still keeps it inside the Jeep. The enclosure will hold the ARB twin or single as well as many of the ViAir compressors.
Jeep Wrangler JL ARB Single Compressor Underhood Firewall Mount Jeep-JL-Gate-ARB-Enclosure-03W
unknownsolo
Washington, USA
22 Wrangler Rubicon 4XE
I didn't know about the brake lines in the 4xe. I bought a twin with another mount and was hit with an unpleasant surprise during the install.
You have some nice options. I'm considering a couple from your site. Thank you for the prompt responses.
Jeep Wrangler JL ARB Single Compressor Underhood Firewall Mount IMG_0827
Jeep Wrangler JL ARB Single Compressor Underhood Firewall Mount IMG_0828
Jeep Wrangler JL ARB Single Compressor Underhood Firewall Mount IMG_0829
GATORB8
CLT NC
Have y’all looked at behind tail light for the portable?
unknownsolo
Washington, USA
It seems like there is still some room for a single by the wheel if you design a vertical mount or something around the brake lines.
