Dragoneggs Build Thread
dragoneggs
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Functional test drive this afternoon and very pleased. Alternator/generator plus solar was netting me 948w charging power. Solar panel generating 148w on its own not even directly aimed at the sun and up here at 47.6deg N latitude!
The output was the charging of the fridge onboard battery.
Jeep Wrangler JL Dragoneggs Build Thread IMG_2514
gek
Code Monkey
dragoneggs
dragoneggs
Seabeck, WA
Decided to design and 3D print a fairing that wrapped around the solar panel. A more finished look that comes close to matching the hardtop, and gives my brick some aerodynamics. This came out great. Each piece simply snaps on the frame of the panel.
Two sections butted together here. Midspan seams are barely noticeable…
Jeep Wrangler JL Dragoneggs Build Thread IMG_2531
Had to design also to fit over the brackets in four locations…
Jeep Wrangler JL Dragoneggs Build Thread IMG_2532
Corner seams are a little more visible but that is a result of the aluminum extrusions not being perfectly square. The accuracy and tolerances of the 3D print are amazing…
Jeep Wrangler JL Dragoneggs Build Thread IMG_2538
dragoneggs
dragoneggs
Seabeck, WA
Just an editorial update... loving the solar panel and going doors off and freedom panels off. Keeping the rear hardtop on keeps my solar power in place and provides a little bit of security for stuff in the back.
Jeep Wrangler JL Dragoneggs Build Thread IMG_2988
dragoneggs
dragoneggs
Seabeck, WA
Finally got around to installing my ARB rear diff cover that has been sitting in the box for close to a year. Tore up the lower edges of the OEM cover on the Rubicon but it wasn’t leaking. I guess I need to wash the underside now. The cover looks out of place…
Jeep Wrangler JL Dragoneggs Build Thread IMG_3077
gek
Code Monkey
:fist bump:
Put my front one on Friday.
Remorseless
NC
Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast, Napalm Compatible, Not Only The Guy Who Defines What A Jeep Guy Is, But Also The Guy Who Defines What A Jeep Thing Is, Guy Who Has The Authority To Do That
I think you need to just get the new one dirty instead of spending time cleaning the rest. Duh.
