Do I need for a relay for this light?
SSVi
Damon
Idaho Falls
2021 392XR
Extreme metal drummer/ large cat wrangler / gun modder
Hey guys, I‘m mounting a Rigid SR 6” light bar on the Jeep and already ran the wire before it got here. It showed up, comes with a nice wiring harness and relay to handle 60a/14v use. I was going to be wiring it up to my AUX4 switch which only puts out 15a, it will have a 5a fuse at the connection point as it only draws 3.4a to begin with. Since I’m still pretty novice in my understanding of relays other than they can downgrade a hot source to what the device actually needs…would I need to use this relay or am I ok running it off the 15a aux with a 5a fuse wiring I already ran?
Thanks for any input!
D
NJJeep Guy
New Hampshire
2020 Hella Yella JLU
The light only draws 3.4 A so you will be just fine to wire straight to the Aux switch. The switches are also fused so you will not harm the jeep with a lower in line light fuse. The relay is made to handle a max amperage of 60, but of course your lights don't actually need that much power
SSVi
SSVi
Damon
Idaho Falls
2021 392XR
Thats what I was thinking too, I just didn’t want to assume and you know…turn my Hellcat Jeep into a Hellfire Jeep ?
Pinion
Rob
Hull, MA
1971 FJ40, 22 Rubicon Unlimited
Project Manager
A relay only handles the trigger that allows full power of the circuit to flow via a switch or other input. It doesn't step up or down volts/amps.
SSVi
SSVi
Damon
Idaho Falls
2021 392XR
Ah ok, thanks!
OllieChristopher
Southern CA
2005 GMC 2WD Sierra, 4.3, NV3500, 3:73/TruTrac
I personally would recommend a relay. Strange things can happen with LED's if you leave out a relay. For maximum output on any light a relay is important. Not to mention it's another layer of protection to prevent wires overheating.
I'm not familiar with the Jeep aux switches. Some manufacturers all ready have a built in relay into the system. Simple enough to check.
I'm running Baja Designs Squadrons on both my Beta and Super Tenere. I never even considered not using a relay. Those LED lights get really hot.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
The aux switches are relayed from the factory.
SSVi
SSVi
Damon
Idaho Falls
2021 392XR
How would one check if they’re built in?
OllieChristopher
Southern CA
That's pretty darn slick!! Bravo for Jeep!!
I purchased a Neutrino PCM for my Super Tenere and already wired in my relays for the Squadrons before realizing they were built into mine as well.
https://www.neutrinoblackbox.com
roaniecowpony
Retired Engineer
Ah ok, thanks!
Think of a relay as a switch that is remotely (wired) controlled by another switch in a convenient location. The relay just bridges a power source (battery or electrical buss) to a load (your lightbar). It literally opens and closes contacts between the power and load.
Carolina Jeeper
Rollie
North Carolina
Relays are mostly used to eliminate higher amp arcing inside of switches when switching accessories off. But of course it's simply a safer electrical system to use remote switching.
