Do I have a lemon?
Virginia
Jeep Wrangler 4xe
This is incorrect.
100% of those miles are hybrid. They just aren't electric only.
The 4xe never runs gas only. What you're referring to as "gas" miles are not gas only. They're hybrid where power is coming from the gas engine AND the electric motor as needed.
When the jeep shows <1% battery remaining, there is actually around 15% state of charge. It's constantly charging and discharging at this lower state of charge as it behaves as a mild hybrid.
I understand what you're saying, but if there is no electric motor contribution, as I stated earlier in my response, how is it "hybrid"? I have trips of 40 miles where there is 0.0 contribution from the electric battery and 40.0 from gas. There is zero contribution from the electric battery.
Gobirat
Gobi
Midwest
Jeep 4XE
Welcome to the Forum, from Cave Creek AZ.
I really don't know much about them. But my Neighbor has one, and he tells me than he gets about 26 miles and then has to re-charge. That doesn't seem like much of a advantage to me. Then one has the electric cost to re-charge it. Hopefully, that doesn't add up to much.
I have one coming and used to be a lineman for a power company. The math works for some and not for others. First off, what is most of your driving. Long haul or short commute. I do 95 percent of my trips in the day at 20 miles or slightly over. So it will be good for me. The other thing you must know is what are you paying per kilowatt hour for electricity. NE where I live is 11 cents per kilowatt hour. The 4 XE has a 17 KWH battery with a usable charge of about 15KWH. So to recharge it will cost me about $1.65 to use the pure electric side of it if I stay in my milage band. I will think of it kind of like getting $1.65 gallon of gas to maybe go say 23 to 25 miles. Another reason I went with it was the available torque and hp figures. Even if out of your juice, u still have a reserve there to get the most out of the engine electric combo since it is a hybrid. Then there's the 7500.00 tax credit and the high demand to get a 4XE. So they should do well when it comes time for resale. While they are not for everyone maybe, they work for many. Especially if u have a plug in at work too and can utilize it coming home if you are over 20 miles away. I don't know everything, but it seems pretty simple.
Gobirat
Gobi
Midwest
Jeep 4XE
Actually there is always an electric motor contribution with a hybrid like this, but you might not achieve the economy u are looking for because the engine will be running so much. With trips of 40 miles, u would need to look at it a couple ways. Is that 40 miles round trip or each way. If its round trip, maybe you are going to a job where u can plug in for nothing. And really utilize it, but if its a 40 mile trip one shot deal. Than do the math. Figure u can do electric maybe 25 miles of that 40 mile trip. Than figure how much gas used for the other 15 miles of the 40 mile trip. Add the gas used to how much it cost u per KWH to charge the Jeep to the get the electric miles. Maybe u will average 30mpg or 35 to make the 40 miles shot. Some quick math will reveal the answer.
Virginia
Jeep Wrangler 4xe
No, that's telling you that of the 40 miles, you did 0 of them on only electric power and 40 of them in hybrid with power coming from both the electric motor and the gas engine.
So on other trips, under the same circumstances, why does it tell me that it is (for example) 3.6 electric, and 61.0 gas? I guess I do not understand how this first number is being defined if I did not use only electric as the "only electric" part was uncharged (<1%).
If the answer is that somehow the battery is recharging enough to use 3.6 miles of it, then how over a 500 mile trip is that not happening? I don't understand the lack of consistency.
mllcb42
4xe HA, 392XR
In hybrid mode, with charge available, it will actively determine if it wants to run in electric only mode or with both the gas and elective motors going concurrently, depending on the load demands, etc. It's totally reasonable and expected that you'd get variations from day to day. Sometimes I can cruise on the highway in electric, sometimes it chooses to bring the gas engine on to augment. Depends on if I have the ac on, if there's a head wind, what temperatures are like, etc.
Gobirat
Gobi
Midwest
Jeep 4XE
[/QUOTE
I do not have my 4XE yet from my dealer, but question the accuracy of those numbers until I can do some test runs for milage and fill up to the brim with gas and electricity and do some math. Verify the milage I went and what the KWH cost and gasoline costs were to try to get some correlation. I just don't think the computer will be as accurate as the old fashioned way. If it is close, it will be fun to watch.
mllcb42
4xe HA, 392XR
It definitely only counts an "electric" mile when it's running electric only.
The mpg estimate, however, is a complete crapshoot that makes very little actual sense.
BXFXJeep
Toronto, ON
2021 4xe Sahara
I have seen this.
When you drive at low speeds with <1% the 4xe will drive a bit in electric only, then the gas kicks in, sometimes it will go a block on electric(think stop/start), usually it's like 1/2 a block, so if you drive like that long enough, then those 1/2 blocks will add up to 3.6 miles
I don't drive that much like the scenario you are describing, so I've seen .5km etc
Pretty much every time you stop at a light or stop sign etc, then pull off, the 4xe tend to pull off in electric only, and will drive electric only for a bit.
Virginia
Jeep Wrangler 4xe
I'm saying there was no charge available, but it still reported something different. I get your basic premise though that the regeneration produced some extra charge that could be used.
I guess my question is - what is the purpose of this gauge then? If the battery icon doesn't represent the electric motor contribution to total mileage driven, and there is no 'gas only' mode so the gas icon doesn't actually represent the gas contribution either (it represents hybrid miles?) - then what is the reason for having it, and how do you know if it's functioning correctly?
(I realize the overall goal might just be to make a consumer feel good about themselves because sometimes there's some number in both spots and not to think to hard about what those numbers mean, but as my degrees are in applied math and I've worked with control systems, I can't help but wonder what the actual purpose is and how they're calculated.)
mllcb42
4xe HA, 392XR
The primary usefulness is to make people feel good about their use. It doesn't really communicate anything particularly useful.
If you really want to verify that the hybrid system is actually hybriding, go to the hybrid page in uconnect and make sure you're seeing kWs flowing between the battery and motors while driving.
BXFXJeep
Toronto, ON
2021 4xe Sahara
The battery represents battery only miles and the gas represent hybrid miles, the Wrangler 4xe is always a mild hybrid.
To know if the Wrangler is functioning properly, you should probably charge it up.
The numbers are extremely easy to understand.
Gobirat
Gobi
Midwest
Jeep 4XE
Maybe forget the gauges for now and just do a calculation based on the gas used and electrical used with the given miles driven. E.g. : if you drive 500 miles in a given time, and used this many gallons of gas and charged it this many times based on your home KWH cost, than crunch the numbers. After u get an idea of what its doing, start analyzing the gauges and see how it jives with your data.
