DIY Goose Gear Style Platform
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I addressed that issue by putting washers around the screw holes that had gaps. That let me tighten those down as much as I needed.
I'm installing the panel that my wife built for our last JLUR into the latest rig and realized that using 3/16" wood is definitely a better approach than what I did last time.
FRV
NC
2003 Suburban 4x4, 2021 JLU Rubicon
3/16"? Typo right?
ssrgeoff
PNW
2021 JTR, 2022 JLURD
3/16"? Typo right?
I would think....
Since we are headed out for a camping trip and my Goose gear is still in production I quickly put one together out of maple ply. It's only temporary but it does the job. I used the entire 3pc carpet as a template. Secured the PLB40 and have tie downs for the cases of kitchen and camp equip. Speaker box carpet from Amazon is complete trash though.
Jeep Wrangler JL DIY Goose Gear Style Platform IMG_0034
Ratbert
PNW
Software Engineer
Looks good, I'm not sure why you are still buying the Goose gear. I'm making my own so I can customize it.
Fortunately my wife is into Jeeping. She also has strong opinions on what she wants. She loves the build quality of Goose Gear products, so we're getting Goose Gear for this.
They build them on demand, resulting in eight weeks of lead time. It's one of the few things that I didn't order back in January, so ours won't be here until after our Rubicon Trail trip. That means that I'm now working on getting our Dometic CD 30 mounted in this Jeep, utilizing the birch platform that she built for our last JLUR.
stingGreyNJ
NJ
2018 JL Rubicon, 2013 JK (gone)
Your build is very nice. Really well done. I'd choose yours over GooseGear anyday.
I did a similar plate for my build but I only replaced the 2nd row seats with a “plate". The commercial equivalent is the $599 Springtail rear seat delete. Issue with this solution is that it isn't flush with back OEM plate for sleeping comfort and doesn't provide a way to extend the platform behind the seats for sleeping a 5' 10" person.
I didn't need to mount to the floor so the back was fine as is and I kept access to the storage cubby in back as it was. See below the basic plate:
Jeep Wrangler JL DIY Goose Gear Style Platform E84EF05A-2E63-41E1-9CF5-7A9276C30F72
Above, the bottom support was temporary here but the top gets sealed and covered in carpet.
Jeep Wrangler JL DIY Goose Gear Style Platform 77A8843E-4C48-465D-8E7A-EFF325DD1888
Above: Plate freshly covered in carpet. Front seats all the way back. All the shelving above ended up changing in the final build I travelled with but the plate stayed pretty much the same. You can see above the flush condition between added plate and existing cargo area “plate”. With just the black carpet it looks pretty OEM.
Jeep Wrangler JL DIY Goose Gear Style Platform 291B7BBA-FA98-4637-96E7-4EEDC5B5FDA4
Above: Cavernous.
Jeep Wrangler JL DIY Goose Gear Style Platform 7402A9A9-9C8D-4C6F-9DD8-9D9AFE0BEDE4
Above & Below: This was how I can access all of the storage underneath. The plate tilted up by hand, the red bungee above the hi-lift jack keeps the back side of it down. Some paracord holds it for access to storage. You can see waxed tarp covering the “bed” area here.
Above: Driver side under floor was shoes and flashlights and dog bowl I would have access to it if the door was open.
Jeep Wrangler JL DIY Goose Gear Style Platform 17E617AC-5FCA-485B-83D1-4F9254FF28C9
Above: Behind passenger seat was recovery gear. Pump and deflators can access easily from the open door. If I was in a recovery situation I'd have to tilt up plate for access to the rest of it.
Tilting plate up involves pushing both seats forward and seatbacks upright. Not ideal but no hatches made for a simpler, stronger design, allowed me to cover the entire platform in a waxed canvas tarp (mostly in case my dog lost his lunch on our journey). And even with hatches that hi lift jack isn't coming out without the tilt function.
You may also notice in the little “wings” in front of the front support. These were hinged and allowed me to drop in plates behind the seat when moved all the way forward to get enough length to sleep comfortably.
Jeep Wrangler JL DIY Goose Gear Style Platform 8D972BD1-834B-43D3-9A7D-2FC9046B52F3
Above: Blackout curtains up. Filler Plates in to extend length of sleeping space. Ready for bed. This also shows my final version of shelving that included a recovery board top shelf to maintain stealth and security and save weight.
Jeep Wrangler JL DIY Goose Gear Style Platform CA26ACEE-FD6C-4062-A1A4-0B6B7F614B2A
Above: Other than the rain deflectors so I could crack a window even in the rain there isn't much indication someone could be sleeping in there.
Thanks for reading if you made it here!
LMK if you have any questions.
Jeep Wrangler JL DIY Goose Gear Style Platform 1FCF6E86-185D-4CFF-8E46-8BCC140298B8
FRV
NC
Thanks. Your plate is cool too because it does what you need it to do. That's the key.
I have found the hatches to be very convenient. You don't have to move much to get to any single hatch. But I like your lift up hinged lid. Maybe you can add hatches and keep the hinged lid for when full access is needed.
LWLjeep
Lance
West Allis
2015 Jeep Wrangler Sport
Really love all the attention to detail. Would love to build sometching like this but not sure the skills, and currently looking at just the rear, for a frig, maybe drawers
Ratbert
PNW
Software Engineer
Thanks again @FRV! Just need to do some finishing touches and figure paint/bedliner out.
That looks nearly identical to what we made for our last Jeep. I ended up cutting a removable opening in it so we could access that storage area underneath.
Viking Jeeper
Jacksonville FL
2006 LJR. 2021 392 Wrangler.
I cut a hole to access the storage underneath but not sure how I'm going to cover it yet.
FRV
NC
Make a simple template from scrap plywood 1/2" larger than the hole you cut out. Then use a trim router or regular router if that's all you have along with a guide bearing above the flutes and set the blade depth for half the thickness of the wood. Then dado the platform. Do the opposite on the lid and it will fit flush. Use a latch like I did or for a simpler version a finger hole, though the later will tend to rattle. There are various catches you can use with the finger hole.
All the pictures and explanations are at the beginning of this thread.
Viking Jeeper
Jacksonville FL
Actually I had planned to do just that, I just have not yet. I have the 392 so the storage underneath is very small.
  • Like
Reactions: FRV
