DIY Goose Gear Style Platform
FRV
NC
2003 Suburban 4x4, 2021 JLU Rubicon
Thanks. Glad you like it.
NyRey87
Nyles
Reno, NV
2021 JLURD
I work in Cabinetry and Guitar building and your build is most Impressive! Great job
Viking Jeeper
Jacksonville FL
2006 LJR. 2021 392 Wrangler.
I am mostly interested in the rear section but don't want to eliminate the possibility of adding the front at some time. For the rear, did you put any spacers under the base? The floor is not flat of course. The plastic bin (mine is 392 so that storage is very small) sits above the rest of the bed. The two strips of support that almost seem to be randomly placed are on the same plane with the top of the plastic bin.
Jeep Wrangler JL DIY Goose Gear Style Platform IMG_8439
FRV
NC
Oh that's nice compliment. Appreciate it. Much respect for luthiers.
FRV
NC
Yes. I used spacers. I cut notches in them and such to ensure a level foundation and then glued those to the underside of the platform. I attached a picture and put a red box around the rear platform. It's flipped over so you can see the spacers.
Jeep Wrangler JL DIY Goose Gear Style Platform BDE4BD42-7C5F-4C81-895B-EA2F6BCB4EC0
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I addressed that issue by putting washers around the screw holes that had gaps. That let me tighten those down as much as I needed.
FRV
NC
Any method that works is probably a good method. So, no one way to do it.
There are not many screws to hold the plate down. I wanted the platform stiff and well supported when we stand on it. My plate rests more on the greater surface area of the stringers then probably the case resting on washers But you have to decide that for yourself.
Viking Jeeper
Jacksonville FL
Thanks @FRV I got my initial template done today. Will cut the platform from some 3/4 that I already had tomorrow. I've done a bit of experimenting with spacers and will use 1/2 inch for the deepest areas and various thinner pieces in other areas. I wanted to extend the drivers side over farther but if I put a slider on that side it cant go that far over because of the tailgate latches. Still figuring out the jack space cover. I would not mind keeping the stock piece as long as I can get it out. I think it will work.
FRV
NC
I recommend you avoid using 3/4" ply if you can. It is overkill and unnecessarily heavy.
I can post a photo of the jack compartment cover if it will be useful to you.
Viking Jeeper
Jacksonville FL
I agree 3/4 is probably overkill but I have two nearly full pieces that are very nice and I don't really have any other use for them.
If you can post pics of the jack compartment cover that you have not already that would be great.
I'm guessing you used 3/4 inch spacers with 1/2 inch wood?
FRV
NC
Yep. 3/4" ply supports glued to the bottom of the plate. Attached are pictures of the jack compartment cover. It slips under the plastic lip just like the original. I made it with 1/2" ply glued to a 2x4 which I milled to get the correct profile on a table saw. You could also cut it with a router or hand planes if you got 'em and know how to use 'em.
Jeep Wrangler JL DIY Goose Gear Style Platform 0B7FB879-78C9-475B-8B66-C5754463B0B1
Jeep Wrangler JL DIY Goose Gear Style Platform A6F1892C-CB62-416D-97C8-95C240E56581
Jeep Wrangler JL DIY Goose Gear Style Platform 5BB1169A-BBD4-4D90-9BA6-568BB47E28FB
