Diff Fluids after Taking Jeep for a swim
MotherBear26
South Dakota
Chevy Traverse
So I went on a trail, and it was unexpected/not planned to go on a trail that was flooded with water. The trail started out fine then my Jeep dropped to where I was pushing water up to in between my headlights. (There was no way out other than to go through the water). I do not have a snorkel nor is my breather tube extended. I have a 2024 Jeep Wrangler Willys. During the trail ride, I was not motionless and kept moving so that we didn’t get stuck or anything. When we got back home, I washed the vehicle and sprayed down the axle areas to get rid of any residual dirt or dust. I also checked my oil dip stick to see if the engine oil looked ok to which it was. I didn’t bother with the transmission fluid as I didn’t know what to do there. My question is about the differential fluids. I have not done anything to see if the differential fluids are ok. I am a little worried that if I don’t verify the oil is ok as in water didn’t get into it then I will have issues in the long run. I was going to unscrew the bolt to see if the oil is a milk chocolate shake color but then after reading some various things about how it will not screw back in once it is removed. (I wouldn’t remove it fully but just enough to see the color and put back in.) How easy is it to do this and if I read my manual right it would be tightened to a PSI of 25 lbs, I believe?? Am I being overly worried? Any suggestions please.
agentdr8
CA
21 JLU Willys
I don't recall how high the axle breather tubes extend upwards, but if the water line went above them, then it can allow water ingress.
MotherBear26
MotherBear26
South Dakota
Chevy Traverse
Why not just change the diff fluid your self if you’re worried. The fluid is cheap and the gasket is reusable. When you’re done instead of worrying you’ll feel like this.
I would love to do it myself, but I have never done it before so I am apprehensive that I will screw something up. Do you know if what I shared above is accurate on the specs for the torque wrench?
I would love to, but I have never done it before and apprehensive that I will screw something up. Do you know if the specs I called out above are accurate for the torque wrench?
MotherBear26
MotherBear26
South Dakota
Chevy Traverse
I also read that you need a new gasket as the current one is not reusable in a 2024
Terrymo
Terry
2023 JLURXR 3.6 ET
Water intrusion is unlikely but not impossible.
I don‘t have any first hand experience with the gaskets on a 2024.
The torque specs are listed here
https://www.jlwranglerforums.com/forum/threads/torque-values-for-jeep-jl-wrangler.17791/
Lots of youtube videos. Here is one and although it shows an aftermarket diff cover the process is the same
You will have to decide if this is within your abilities. If you have a local Jeep club there will be people who are willing to do, or help you through it.
BobW
Bob
Ventura County
2018 JLUR 6sp MT; 2019 GC; 2021 Lego JLR
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
2nd changing the fluid if you are worried about it. One of the easiest maintenance jobs you can do yourself on the Jeep. Biggest risk is dumping diff fluid on your driveway, pretty easy otherwise.
Get your Youtube certification and let er rip.
hamiamham69
Nantucket MA
2019 Unlimited Sport
If you don’t want to fully commit to a diff fluid change do this: Put a bucket or other container under one of the diffs and remove the fill plug. Using a small pump remove some fluid and examine it. I think it will be somewhat obvious if y have pure diff fluid in there or if it has been contaminated with water and dirt.
depending on the year they may not have a drain plug. I do on my. 2019 but I know other years require you to take the diff cover and the gasket off.
