Determining "real" suspension height
darylm74
Daryl
Oldsmar Florida
2021 JLU Willys
Sr Data Engineer
I bought a RockCrawler 2.5 inch lift for a diesel but after getting it installed, high clearance fenders and 37's, it definitely seems a lot more than 2.5. I used this as a gauge to determine actual height
https://www.wranglerforum.com/threads/jl-jlu-average-factory-height-diagram.2453097/
I have 15.5 inches vs the 10 7/8 from the measurements listed for axle to spring capture. This seems more like a 4.5 inch lift. I had 2.5 in my old JK and didn't seem that high. After this one, especially after a Crossfit class, I feel like I am climbing up a mountain. Concerns are drivetrain and making sure I have the shafts updated. I also seem to be rubbing slightly in full turn on the driver side against the front lower arms, but not when turning to the passenger side. I have stock rims but 2.5 inch spacers. A couple of pics of my rig.
Jeep Wrangler JL Determining "real" suspension height 20231006_164700
Jeep Wrangler JL Determining "real" suspension height 20231006_163927
Camaroboi13
Justin
San Bernardino, CA
2022 JTOD, 2024 JLU W
LEO... life in Chino
Do you seriously have 2.5” wheel spacers??? ?
Anyway, just by looking at your jeep, it looks like it has a 3” lift with 35.5” tires and higher than factory fenders. I don’t see 4.5” of lift there personally.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
For anyone thinking about a lift, just take a measurement under the spring and above the spring; axle housing to frame rail for example. Ground to frame rail. After the fact is harder because you don't know the pre-lift measurement.
Roky
Roky
Ask on here, or if you know someone with a stock Willys or stop at a dealership and measure from top of the axle to the upper coil housing like in the pic …… then measure yours, the difference is how much lift you actually got………
Jeep Wrangler JL Determining "real" suspension height IMG_3861
darylm74
darylm74
Daryl
Oldsmar Florida
2021 JLU Willys
Sr Data Engineer
I was looking to be sure as I don't remember if I put 2 or 2.5 spacers but needed quite a bit of space to keep the stock wheels and was a lot cheaper. The tires are 37's but technically KO2s are 36.5. I am going to need to find someone with a stock diesel willy's which may be difficult to find to measure exactly but the 10 7/8 was the average according to the link I posted. Per Roky's picture, that is the same measurement I got 15.5.
Westymike
bio.site
2021 JLR 2.0 8spd Auto
Digital Marketing / Brand Manager
certain lift heights are based off of a specific models with aftermarket skids, bumpers, sliders installed. Base models with stock parts will sit higher as they are lighter. Just something worth noting…
LazyJL
Larry
2020 Rubicon, 2001 built XJ
Retired fabricator and mechanic
The factory shop manuals for TJs and XJs have actual height measurements for the front and rear axles indicated by measuring the distance between the top of the axles to the bottom of the frame.
This provided a baseline for measuring suspension height.
I cannot find the same for JLs, there doesn't seem to be the same baseline measurements available for JLs.
Does anyone know differently?
Camaroboi13
Justin
San Bernardino, CA
They advertise them as 36.5 but yep, 35.5 according to the Stanley Tape Measure. False Advertising :(
That’s one of the reasons I want to go 38s, hopefully I can end up with a real 37” tire.
