Dead battery red sentry light
mgrowc1
United States
Wrangler
Random question but I am confused since we have two batteries. Had to jump my jeep off the main battery as wouldn’t start. Firstly does that mean my main battery is dead and the ess is ok? I’m confused now as the red sentry light is still on so I’m hoping that goes away with a new battery?
mgrowc1
United States
Wrangler
Well the light went off when I restarted it so I am gone there. Will get a new battery tomorrow hopefully.
58Willys
Geoff
Western Washington
2018 JL Sport
Make sure your charging system is charging the batteries before assuming the batteries are bad. Check cables connections and grounds. If charging and cable connections are OK, load test the batteries separately. Make sure to replace both main and aux batteries at the same time, as one bad battery can kill the other one.
mgrowc1
United States
Wrangler
The dash says it is getting the right volts so I think I am good there. I was only going to change the main. If it gets killed because the aux needs to be changed I guess I have warranty for that so should be good.
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
Always replace both Main and Aux at the same time. They work as a pair. If you only replace one at a time you will go through batteries much faster than you should. To maximize lifespan, Main & Aux must always be the same age and wear.
