Dashboard warning lights
Vern
Vern
Livermore, CA
2018 Jeep Wrangler Unlimited Rubicon
2018 Jeep Wrangler JL Rubicon. While driving random warning lights come on the dashboard. The lights are gone after a ON/OFF cycle with the engine. However, the check engine light remains on until three ON/OFF cycle with the engine. Also, several times the ABS, BRAKE and other warning lights are lit when the engine is first started. This will cause the Jeep not to go into gear. After an hour of waiting, the Jeep will start and go into gear, and no warning lights except the check engine light. Again, the check engine light will clear after three ON/OFF cycles with the engine. Any suggestions on the cause? This issue has been occurring for months.
MountainsOcean
Vancouver BC
2020 JLU Sahara
Check your fuse box, go one by one and make sure the fuses are pushed all the way in.
Apexcars
North Texas
2020 RAM 1500
Are you using Amsoil?
Seriously though, a quick search for the words dashboard lights would have come up with this exact scenario in many, many times.
SBLACK502
Charlestown, IN
2021 Jeep Wrangler
also, if you had the aux battery make sure you change them both at the same time.
melendez69
Marc
Waxhaw NC
2018 3.6 JLR / 2013 991 911 / 2013 E92 M3
...huh?
If you're on the original batteries, they're a few exit ramps past their reliable shelf life. It's been mentioned here that a bad battery will throw many different errors with the stock setup. The bad one will take the good one along for the downhill ride.
You should start with replacing both at minimum (or just the larger one) and bypass the little auxiliary battery (as many, many will recommend).
HeN2O2
Shell Beach, CA
2023 JL Rubicon Diesel; 1983 CJ-8
There is also this...
https://www.nhtsa.gov/recalls?nhtsaId=24V652#recalls480
The newer electronics, especially the batteries and CAN Bus systems, are possessed. For the most part my Jeep works fine. If it sits and the batteries get low, I might get a Can Bus communication error on a cold start. If I turn off the engine while the Jeep is still in gear, I get a warning on the dash, which is to be expected, but also a check engine light with no error code for a few drive cycles. Both JSCAN and Banks Data Monster show the check engine light as being off.
Old Dogger
Bill
Cave Creek Arizona
Have your Batteries load tested!
Vern
Vern
Livermore, CA
The original Auxiliary and Main battery was changed three ago.
Replaced both batteries again.
The Jeep seems to be OK for now.
Vern
Vern
Livermore, CA
After 2 months the issue has returned. Random warning lights and the check engine light come on the dashboard when driving. So it is not a battery issue.
