Dashboard light
Nor68
Noreen
Superman11
2020 Jeep Wrangler
Anyone know how to reset or remove the A! With a yellow circle around it, near my odometer?
Jeep Wrangler JL Dashboard light F87721AB-8ED6-44EC-AF1B-B0263E1B5639
Bulletbill
Tom
Central PA
2021 JLUR
Do you have etorque?
Issue with the start stop system, some on here have had issues with the battery for the system.
Nor68
Noreen
Superman11
2020 Jeep Wrangler
No, on the etorque. Should I disconnect the battery?
TheNewGuy
Wes
NH
Chances are your Aux battery needs to be replaced. If your JL is coming up on or more than 3 years old, you'll want to check the main battery too and replace them both.
Nor68
Noreen
Superman11
2020 Jeep Wrangler
Thanks, it’s a 2020. But I will check both.
Capricorn
Las Vegas, NV
2024 JL Willys XR V6
Network Architect & Engineer
May well be a battery issue but there are other causes too.
Make sure the hood is closed properly. These hood sensors if they see the hood open may generate that error too.
Jeep Wrangler JL Dashboard light 1638733746979
On my previous Wrangler, it was a shorted wire for the ESS that was generating the error. Can also be a bad relay.
lalalofsky
Ben
Lawrence, Kansas
2020 JLU Sport
My 2020 did that off an on for the first 10k miles, my dealership is horrible in lawrence so i never took it in. It hasn’t happened Since about 11k miles…. Not that that helps much
orangemachine
Vermilion, Ohio
2018 JLU Rubicon
hello , just had my 2018 wrangler jl rubicon in dealer on 12-3-21 in for same issue, at first the service advisor told me no fault codes were showing for problem i described after we had string of cold weather days here in ohio and asked him if the cold weather could affect the start stop computer workings he said no and i told him i read on jeep forum some weather conditions affected the system he laughed at me. i then told him i wanted it checked out, he told me the cost would be 120.00 for tech to check out, told him to do it, after jeep was serviced the tech found out via computer and running diagnostic that it was a faulty abs module. service advisor told me it would be 500.00 plus tax to replace module. Needless to say i have to make an appointment to get it replaced and service advisor iam not happy with since his service diploma says he has been certified for only one year.
Capricorn
Las Vegas, NV
Are you out of the 36k/3 yr warranty?
Nor68
Noreen
Superman11
2020 Jeep Wrangler
Awesome, I will check that out too!!
Nor68
Noreen
Superman11
2020 Jeep Wrangler
My warranty is 60,000 5 yrs, so I should be good. I think I’m in the wrong field..lol thanks for the info!!
Bergerboy
Leigh
Michigan
2021 Wrangler Willys
Awesome! A Meatloaf reference!
