Creaking front passenger seat while seated
Komi85
Philadelphia, PA
2019 JL Rubicon
JeepCares
Auburn Hills, MI
JL
Yea my drivers seat is creaking now. Is this a recall issue?
I'm also hearing some type of clunking noise from directly below the passenger seat only on turns, not straights--not sure if it is due to the seat itself or underneath the car.
Think it may be related to this issue: https://www.jlwranglerforums.com/fo...e-when-turning-left-or-right-low-speed.17067/
@JeepCares, any idea what may be causing that sound?
Hi nypharm and Komi85,
We certainly understand your concerns. Unfortunately, we are unable to determine the cause of the sound you are hearing. We suggest having your dealer inspect this concern if you have not done so already. We would also like to have this documented and looked into further so please send us a private message if you decide to have this addressed by your dealer.
Lydia
Jeep Social Care Specialist
Trollboogie
Keith
Jersey Village, TX
2018 JLUR Hellayella, 2021 Mojave, 2006 GTO
Machinist
Just to let everyone know.... The grease thing works. Just unbolt the seat and lean it forward so you can get to the the plastic cover where the seat hinges.( The center console side, 2 phillips screws ) You will see a tube that goes from one side to the other. It's not the actual hinge point. When there is someone in the seat, their weight makes the flared part of the tube slide a little against the flat bracket. Get some bearing grease and force it under the flare of the tube and the bracket.....all done!
Phillip Akin
Phillip
Montgomery TX
Jl Rubicon
Month old JLRU and passenger seat now sounds like it is going to fall apart while someone is seated. I was worried I was the only one. Sounds like a little grease may do the trick. Does anyone have any longevity updates after applying the grease?
JeepCares
Auburn Hills, MI
JL
Hi Phillip Akin,
We are sorry to hear about your seat concern with your new JL. As stated to other forum members, we would be happy to add an additional layer of assistance to this process. Just send our team a private message!
Alex
ITSTHEWIFES
Las Vegas
18 Wrangler Sport. 06 Toyota Matrix xrs. 13 Chevy Sonic
Is this just a creak? My passenger seat sounds like a loose bolt, or something. Almost like when you adjust the seat position but don't get it just right in the click, and then suddenly it clicks. I hope you know what I am talking about and not just crazy. It only happens when someone is sitting in the seat. Will poke my head under there soon as I can, just wondering if any of you know what it could be, point me in the right direction. I did a quick search of TSBs and whatnot, but haven't had access to my actually computer until now, and I am not too good at searching things on my phone.
jetpuck73
Trenton, MI
2018 Jeep Wrangler Rubicon Unlimited
I have had my Jeep at the dealer since last Thursday and today they told me it is the seat frame and that their is a new revision that won’t be available until June 18th, I will have to take it back then to get replaced.
Trollboogie
Keith
Jersey Village, TX
Machinist
Yep, that's what it sounds like. You won't be able to do anything from the bottom. You have to get to it from the side plastic cover. You don't need to unplug anything, just take the 4 bolts that hold the seat in and get in the back seat... Then lean the whole seat forward. It sounds like it is coming from the seat rails but it isn't.
Mane
St. Pete FL
4Runner LTD
First post, and came here to add myself to the passenger seat clunk list. I've had it to the dealership once, and was told that the seat rail bolts needed tightening. Problem was fixed for almost a day that way, and now the sound has returned. It's super annoying. I may try the grease method if getting the seat corrected at the dealership again turns into a pain...
JeepCares
Auburn Hills, MI
JL
Hi Mane,
We are sorry to hear that your concern has returned. If you would like any additional assistance while working with your dealership to address this, please send our team a private message!
Alex
Kevin Mojito
Kevin
Washington
2019 JLUR Moijto 2005 TJ AEV Hemi
Got my new seat rail. No noise any longer, but now it has to go to the paint shop:headbang:
Why cant these guy get a second hand to remove the seat out of the Jeep.:facepalm:
jforse
J
Minnesota
2018 F-150 XLT Sport, 2018 JLUR
Aerospace Quality Engineer
They f'd up my paint too. I wouldn't let them fix it. Dont know how bad yours is but it may be worth it to touch up yourself. Check you plastic too they trashed my sill plastic.
Kevin Mojito
Kevin
Washington
3 inch long down to bare steel, about 1/4 wide. Yes, hit the plastic too. Total animal, no brains.
Cypher
J
AZ
Cybersecurity Leader
My 2019 JLUR passenger seat started this a few weeks back. Seems to be getting much worse the more we drive. Luckily mine is already being repurchased so hopefully my replacement order does not do the same after time.
It was odd, was fine for close to 8k miles, then just started out of nowhere.
