Passenger side roll bar plastic frame is creaking bad
Zalmy
Georgia
2019 Jeep Wrangler JL Unlimited Rubicon 4X4
[GALLERY=][/GALLERY]
Hi all, so My jeep just developed this issue about 2 days ago when i put the doors back on. On every turn or acceleration or anything that isn’t normal cruising such as bumps, the passenger side frame creaks like crazy, sounds like a plastic issue but i’m not totally sure. I tightened the bolts around it and made sure everything was in the same position as the other side, but no luck. I have the noise pinpointed to that area. If i were to describe the sound it would be constant pops of plastic creak, not a high pitch noise at all. Any help is appreciated again this only happened 2 days ago when i put doors back on
Zalmy
Georgia
Oh and i forgot to add it isn’t the soft top. I took the top off and the issue was still there.
Tumbleweed
Anthem AZ
18' JLU Auto 3.6L
So I think I had the same creak as you but mine was on the drivers side. i actually created this creak by accident. I noticed the drivers torx windshield bolt near the sun visor was completely loose when offroading one day. Once i tightened it the creaking started immediately after and even if i loosened it the creaking still continued.. I had to loosen the windshield bolt, put a bolt in the roll cage where the open hole is on the top and then tighten the windshield bolt. Havent had a creak since
See https://www.jlwranglerforums.com/forum/threads/creaking-sound-from-driver-side-pillar.13237/
Zalmy
Georgia
Ok. i’ll look into that. Do you remember what kind of bolt you put in?
Tumbleweed
Anthem AZ
18' JLU Auto 3.6L
I dont i just happened to find one laying around that fit. i think theres a link in there to get the bolts on amazon though
JeepCares
Auburn Hills, MI
JL
Hi Zalmy,
I see you have gotten some helpful advice from your fellow forum members, however, if you decide to have your dealer address this, please send our team a private message and we would be happy to offer some additional assistance throughout this process!
Alex
Jeep Social Care Specialist
chadc880
Chad
Simpsonville, SC
2018 Jeep Wrangler
Zalmy, Check your drivers door. I too thought my plastic parts were creaking after putting the top and everything back on. A few days later and carefully trying to locate the noise in my case it appears to be coming from the inner frame part of the drivers door. A major pain in the arse. I tried everything to avoid a trip to the dealer which I know is not going to be able to do much.
Zalmy
Georgia
So Just an update, As of now my issue has been resolved.I took it into the dealer and they installed a heavy duty bolt into where a normal hard top bolt would be. I did this by myself, but i didnt tighten it nearly as hard as they did. The bolt is so tight in there that i guess the pressure has stopped it from causing the metal to move and create the creak noise.
