This is an interesting threadCoolant reservoir almost empty at 14000 miles. Any ideas why so low? What coolant is a good replacement?
Per the 2021 manual the coolant is the same in each engine.This is an interesting thread
Unfortunately most references are to 2.0 4cyl or 3.6 engines
I haven't seen something dedicated to us 3.0L Eco-Diesel owners
I would believe there has to be some difference, although I'm not a mechanic
Much appreciated on this thread
Watching ?
Isn't orange propylene glycol and green ethylene glycol? The later being sweeter and more toxic to animals and jeepers.JL Sport S 2018 3.6 ESS. N American vehicles use Orange.
Yep. My new JLUR has the overflow reservoir full at the max level line.Not sure I'd agree with it being normal. It has high and low level markings.
Perhaps you looked at the coolant level markings when you JL was warm/hot.Yep. My new JLUR has the overflow reservoir full at the max level line.
Correct. When warm, my coolant level is at max line, and a notch below the max line when cold.Perhaps you looked at the coolant level markings when you JL was warm/hot.
Typical when a JL/JT is cold ,(has not been run in hours) is you see the coolant level between the min and max lines..... closer to the minimum line.
