Coolant reservoir empty
GolfFL
Golf, FL
2020 Willys JLUD, 97 TJ
Coolant reservoir almost empty at 14000 miles. Any ideas why so low? What coolant is a good replacement?
BDinTX
Dallas, Tx
I tried finding something at Autozone that had the required MS numbers and wasn't able to. I didn't feel comfortable with anything I saw there so went to the dealership and got the overpriced Mopar branded stuff. I believe the 50/50 pre-diluted is MS.12106 and the full strength is MS.90032. I'd verify in your manual though.
BDinTX
Dallas, Tx
Not sure I'd agree with it being normal. It has high and low level markings.
NewbJLUOwner
JLU Rubicon Diesel 2022
This is an interesting thread
Unfortunately most references are to 2.0 4cyl or 3.6 engines
I haven't seen something dedicated to us 3.0L Eco-Diesel owners
I would believe there has to be some difference, although I'm not a mechanic
Much appreciated on this thread
Watching ?
Come2elmo
South Texas
07 Chev 2500 HD, 16 Chevy Burb
Watching ?
Per the 2021 manual the coolant is the same in each engine.
OldBlue
Doug
Chatham Twp, OH
See my Signature
Aerospace Forgings Test Lab
If you've got a 2.0L, it's not normal at all. See HERE.
At Risk Ute
Christian
‘23 392 XR
Retired Navy
Refilled my empty reservoir with distilled water after 12k miles. Need to pick up the MOPAR specific coolant.
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
JL Sport S 2018 3.6 ESS. N American vehicles use Orange.
Isn't orange propylene glycol and green ethylene glycol? The later being sweeter and more toxic to animals and jeepers.
slowcrawlerZJ
Chad
Oklahoma City
2019 JLUR, 1982 CJ7, 2018 WK
Retired Navy
You can buy Mopar coolant at the dealership or off of Amazon. Amazon has concentrate and 50/50 mixed fairly inexpensive. I just flushed both of my Jeeps and went with concentrate because you can get more out of it once you mix it with distilled water. I do a 60/40 mix of water to antifreeze and add a bottle of Wetter Water to it.
Mopar 10 Year/150,000 Mile Coolant Concentrate https://a.co/d/g989GTA
Capricorn
Las Vegas, NV
2024 JL Willys XR V6
Network Architect & Engineer
Yep. My new JLUR has the overflow reservoir full at the max level line.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
Perhaps you looked at the coolant level markings when you JL was warm/hot.
Typical when a JL/JT is cold ,(has not been run in hours) is you see the coolant level between the min and max lines..... closer to the minimum line.
Capricorn
Las Vegas, NV
Correct. When warm, my coolant level is at max line, and a notch below the max line when cold.
