Cookie Cutter Wheels for Overlanding.
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
Sounds like a great trip. If I was you, look for a set of Rubicon take off wheels and tires. They are easy to find and can be found on the cheap. You can easily do the Alpine Loop with a stock Jeep, well Ophir, black bear, and Imogene can be done also. Heck I saw a 2wd chevy Silverado at the top of Engineer Pass.
I found the passes in Colorado to be relatively easy going. Red Cone, may give you a problem, but that was not on your radar anyways. With 33 in tires, you could do Red Cone also.
Sounds like a great trip. Take plenty of pics and post them up so you can take us with you.
blnewt
New Mexico
Just ask @cosine he knows!
Have a blast! I think Ted has good advice about Rubicon take-off wheels/tires. The Michelins are very conservative All Season tire made for best MPG and on the road driving. The Rubicon BFG tires are a much better tire for the trails w/ that All Terrain tread block. Not sure how the Michelins would do when aired-down.
blnewt
New Mexico
Kreepin1
Kirk
Central Illinois
1982 CJ7, 2006 TJ, 2012 JKR, 2021 JLR
I recommend the Cooper S/T Maxx, tough 3 ply sidewall, remarkably quiet as long as you rotate them regularly.
01tj
jason
Fairmont WV
Previous 2001 Wrangler, Kia Optima, possibly 2018 Wrangler unlimited
I think I am going to do with 255/80R17 tires on Mopar winter (steel) wheels.
I played around with different sizes on my TJ and 33x10.50 was my favorite. I had a 4cyl and it seemed like wider tires killed power on the highway as well as gas mileage. Most of the guys in my Jeep club had 35's or 37's and I had no issue keeping up with them.
four low
central New York
2018 JL
As mentioned earlier, sidewall thickness is key. I had a dog bite through the sidewall of my P metric stock tires, so Sidewall thickness Matters...tall skinny tires give great traction, and don't rob hp and mpg...
dbbdbb
Ohio
'21 JLUS 23b, 44 rear, tow, tint
I agree with the skinny tire rationale for overlanding. I ran 255/70R17 KM2's on my Xterra and they dug down to hardpan quick in the muddy sections. They were load range E and very stiff, though. Take a look at the BGF KO2 in 255/75. I think you might want more open pattern than your All-seasons that will shed mud better. They're available in load range C and will air down nicer / ride better on the road / wear longer. The K02 is a great option when a full-on Mud Terrain is overkill.
blnewt
New Mexico
The Gladiator forum has a rather epic thread on true pizza cutters, the Kenda Klever RT in a 35x10.5x17, seem to get great reviews over there too,
https://www.jeepgladiatorforum.com/forum/threads/kenda-klever-r-t-kr601-35x10-50r17.28656/
dogbreath650
Bobo
06 LJ Rubicon
There isn't much/any technical rock crawling on the Alpine Loop. You'll be fine with pretty much whatever tire you decide on.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
I run 285/75R18 Duratracs.
It's really tall and skinny the way I like it.
entropy
Foothills of the San Gabriels
OF top 1% content creator
You can always get takeoffs A/T from a JL sport for almost free if not free.
The ones on my profile pic are the stock 32s AT. I have the same setup you have, JKS discos, rubi suspension.
Roverhi
Peter
Kailua-Kona, HI
1970 Series 2 88
Any one used the 34/10.5/17 BFG KO2's Seems a good compromise tire for width and height. Also come in a 'D' rating so not as stiff a sidewall as an 'E' for more comfortable ride off road yet more sidewall strength than 'C' .
wibornz
Ted
lansing, Mi.
www.instagram.com
I saw a 2wd Silverado on top of Engineer Pass. I am sure I could pull my camper on the Alpine loop.
