Control Module Software Update CSN Y40
swflfireguy
naples,fl
2019 JLU Sahara
Retired Fireman
I came here to see what. if any, change is noticed. There seems to be none. And as stated above it's emissions related. I think I'll pass on this one for now. FWIW I have 107K miles and no issues so far.
AZ Hella
Sonoran Desert
JLUR
I am having this software update done tomorrow. I have a 2019 2.0 e-torque. It is for the PCM and PIM. Has anyone had this done? I only have one 12v battery. After I replaced it my stop/start stopped working. I get the message stop/start not available battery charging. 12v battery shows 14.1 v. This has been going on for around a year. Hoping this update might help this.
14.1V resting (engine off) or 14.1V while running? If it's running then your alternator is throwing lots of charge at it. I would guess the resting voltage is probably in th low twelves. The aux batteries are known for taking out the main battery. Just happened to me and I went ahead and bypassed the aux. Now I'm trying to save the main with my Noco10 battery charger.
kah.mun.rah
Merenkahre Jr.
Duat
Anyone know if I have to unmarry my Tazer to have this update done?
Rogersocal
Roger
2020 Rubicon Recon 2.0 turbo, 2018 Ram 2500 6.7 TD
Yes, Anytime you have an update to ECU/PCM you should unmarry the Tazer.
kah.mun.rah
Merenkahre Jr.
Duat
I am using my Tazer to calibrate my new differential re-gear. Any harm in driving on 4.88s when the Tazer is unmarried and the Jeep thinks it has 4.10s?
Rogersocal
Roger
Hard to say, I hear it can go into limp mode but i don't know for certain. Funny you bring this up, im getting a regear on the 18th and they told me to setup the gear ratio before going home so that it wouldn't go into limp mode.
