spaghettipie
- Jul 17, 2019
- Northern NJ, USA
- 2012 Audi A4 Avant s-line, 2012 Subi Impreza sport hatchback, 2010 MB GL350, 2013 Lotus Evora S, 2020 JLU Sahara
Between the link shared by toolman514 and the other posts, the trim differences are well covered. Not mentioned in the posts, but in the link: 2 door not available in Sahara, and Sahara gets an upgraded suspension compared to Sports/S (Rubicon is heavier duty than both).Sahara - Standard painted fenders, and most of the options from a Sport S are standard, available automatic 4 wheel drive, 18" aluminum wheels, 255/70R18 HT or AT tires, Automatic transmission equipped Saharas are now all Mild Hybrids (Etorque BSG)
Rubicon - same luxury features and optioins as a Sahara,
Sahara is the only trim in USDM with an optional 5 position transfer case, 3.6 etorque, and leather wrapped dash panels (that are still designed be hosed down if you so desire).
Rubicon is the only trim in USDM with factory locking diffs, lower gearing, disconnecting sway bars, etc.
OP I do understand your question regarding the trims from the perspective that you need to think about the Jeep you want, and how you will use it. For some car models, it’s as easy as picking the highest trim and ticking all the boxes & building the most expensive version you can afford to have the best that model has to offer. With the JL, deciding first how you will use it will lead to more happiness with the trim you ultimately picked down the road, compared to just building the most expensive version you can. You can build a 59k+ Sahara, a 42k 4 door Rubicon, or even a 62k one - but what are your plans for it?
