Clunk when turning over bump
Twisted Patriot
SE Michigan
2021 Jeep Wrangler WILLYS
U.S. Military Vet, Former Corrections Officer, Current Maserati Claims Specialist
Question.. I recently started hearing a clunk when turning over bumps or up into my driveway.. sometimes when turning right.. sometimes when turning left.. I got under the jeep and everything seems ok.. but, I noticed I can turn the drag link and the tie rod rotationally and make them clunk by hand. I know a little rotational movement is normal but they shouldnt clunk should they? I dont think there is any lateral play, at least by hand. But rotationally i can make them clunk when rotating them. Im thinking this is the cause of the clunk when turning over bumps but wanted to get some experienced opinions before I toss money at it. Thanks guys
occasional_offroader
indio,ca
2021 Jeep wrangler Sahara Unlimited
I would start with checking wheel ball joints especially if you have bigger tires. Then check ball joints on tie rod, this was the cause on my jeep. I ended just upgrading all the front steering components - wheel ball joints, tie rod, drag link and track bar
  • Like
Reactions: gek
gek
Code Monkey
I chased a clunk for over a year. Ended up being my trackbar on the frame side. I torqued and retorqued everything to spec multiple times. It was apparently not tight enough to hold it in all conditions. I ended up putting a gopro underneath and seeing what moved. I tightened it down some more and it got rid of my clunk.
Twisted Patriot
Twisted Patriot
SE Michigan
Well.. I have an aftermarket track bar.. so I think im just gonna install heavy duty ball joints, drag link and tie rod all at once.. get it over with..
gek
Code Monkey
I had an aftermarket track bar, steering and ball joints.
