Closed Winch Set Up
ResqFE
Ron
Ensenada Baja MX
2018 JL Unlimited
Thoughts on this set up versus a Factor 55?
Jeep Wrangler JL Closed Winch Set Up 20200609_204525
JoshuaaT
2018 JLU 6 Speed
Seems fine as long as you have some soft shackles and some other rigging straps. I’m no pro though.
dustdriver
E. Oregon
www.jlwranglerforums.com
2018 Unlimited Rubicon
I remember Factor55 had this question on their FAQ:
Q; Why cant I just run a shackle through the end of my winch line?
A: Most thimbles are designed to collapse under hard pulls. When this happens trying to run a standard 3/4 shackle pin through the end of your winch line is impossible.
Jeep Wrangler JL Closed Winch Set Up factor55
Sheepjeep
Ma
01 xj, 04 Silverado 2500hd
it is fine, it gets you the same benefits for a fraction of the cost
looks like factor 55's argument against it is more you might not be able to use our product then so use a 3/4" shackle
cosine
NY
2019 Wrangler Sport jl
Gone Postal
that will work just fine. it just a simpler and cost effective way in winching. also by going that route you dont have to worry about the line falling off the hook, etc.
