Climate Control Not Working
Brew211
Peoria, Arizona
2018 JLURM, Tundra, 2022 JLU 392 XR
Has anyone experienced their Climate Controls not working? Mine is stuck on front & rear defrost at 76 degrees. Buttons don't work on the screen or on the dash and when I slide the temp gauge, it goes back to 76 within a second.
Thanks for the help,
Brew211
Brew211
Brew211
Peoria, Arizona
I figured out the problem...... both my rear defrost and recycled air buttons are stuck in the pushed position. I don't know how and I don't know how to free them permanently. I gently pried them both loose but as soon as I push them they stick again. Any ideas?
Jeep Wrangler JL Climate Control Not Working IMG_0617
garyji
Gary
Western NC
Hmmm . . . could something sticky have gotten spilled in there?
That's all I got.
G.
captainstabbins
Doylestown
2018 JL Sahara
You could try a toothpick with alcohol on it and go around the outside of the switches. Or you could pull the switch panel out and see if you can access it from the back
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Are you still under warranty? What's the likelihood that it's your fault?
To me, it sounds like bad switches.
Dave928
Washington
2020 JLU Rubicon, 03 Silverado, 88 Porsche 928 S4
Aircraft Tech
spray some electrical contact cleaner in them
Aonar
N.W. Iowa
2012 Rubi and Snazzy 2021 JLURD
Here is an update on mine. In my pic below, the mirror heater button is definitely my culprit. When I pried it out, all my other button worked. When I depressed it, it did come on, but it stuck on AND none of the other buttons would work. Now, just to figure out why it is sticking. BTW, this issue does not affect the proper operation of ANY of the climate controls via the radio screen.
Jeep Wrangler JL Climate Control Not Working climate1
