- Marc
- Nov 15, 2019
- Eastern Washington
- 2023 Rubicon Unlimited
- Banned
Decided to go with the Clayton 1 1/2" springs for a very modest lift to fit 35" tires and still leave a bit of space. Going to try it with stock shocks but will be adding Metalcloak front and rear adjustable track bars and there bump stops. Also using the longer Mopar front lower control arms. attached is a picture of the Clayton and stock springs, the Clayton are the 2 on the bottom. Was a little surprised that they are the same length, Clayton says you will get the lift from spring rate. Should finish up front today, doing a bit at a time.
