Charging Port Door "E" Badge
HushJeep
BC, Canada
2021 Rubicon 4xe; 2024 Willys 4xe
Jeep Wrangler JL Charging Port Door "E" Badge e
Jeep Wrangler JL Charging Port Door "E" Badge charging port door
I ordered a "4xe" badge and want to use just the "e" affixed to the charging port indentation as it's a perfect size match. The badge letters have thin black adhesive foam on the backside however it won't stay affixed to the charging port door. For prep, I cleaned the plastic with isopropyl alcohol and even used clamps to hold it in place for a few hours. No luck. Later, I tried a similar process using glue but that didn't work either.
I saw another forum member do this but I can't remember who it was. Has anyone here done this? If so, how did you affix the "e" securely?
Thanks!
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
Trade that foam out for heavy duty 3m adhesive or paint the E with color matched paint and clear coat. You may also need to use an adhesive promoter.
Storm Cloud
Huntington Beach, CA
2023 JLUR 4xe
I did do it and it fits like it was made for it. It comes with it’s own adhesive tape but I’ve read that it tends to break down against the plastic, over time. I prepped it with alcohol like you did and I added a couple of drops of gorilla glue and stuck it on with the tape. It’s perfectly secure so far! I’m not sure why yours came off so easily but maybe your adhesive tape is bad?
Jeep Wrangler JL Charging Port Door "E" Badge 75EC8ECE-43FA-4991-AB1A-B3927641AA0E
JL plug
George
Maryland
2021 JL
I used Gorilla glue on mine as well. Holding up for 4 months so far.
Morejeeps
Illinois
‘21 Cherokee 24 Wrangler S 4xe
I ordered one and it will not fit properly. I’ve tried gorilla glue with no luck.
us3r1d
robin
CA
2024 Wrangler 4xe Rubicon X
Andy@AAV
Virginia
2022 Gobi 4XE, 2010 Toyota Tacoma
UxS Engineer
Telling myself I don’t want this mod but…
Try roughing the surface with sand paper and use a 2-part epoxy?
