Centerforce vs. South bend Clutches
Mandalorian
MANDALORIAN
Las Vegas
2019 JLU SPORT
This weekend after 2yrs and 40k miles The clutch has begin slipping. It has taken some major abuse and I decided with the amount of times I've smoked the clutch it probably has closer to 100k miles on it :/
Ive had the issue with not going into gear and poor shifting since last summer. I thought it was something to do with the heating of the hydraulic fluid but it seems that is not the case.
I would still recommend this clutch to others. But would not recommend letting me drive it.
Anyone use the south bend clutch yet? I searched it on this forum but couldn't find any good info.
I will decide today if I'm buying the newer version of the CF clutch or getting the south bend so I can compare the 2. I did notice the CF clutch comes with a lot more parts then my version did.
BuyHold
Tim
Washington
'21 2-Dr Rubi, '23 JTM
Could you clarify which clutch you are currently running? I am guessing CF... and if that is the case is it dual friction or the II?
Canjeeper
William
BC
Rubicon
Good luck
Good luck trying to find info on a flywheel and weight from Southbend . unless things have changed .
Mandalorian
Mandalorian
MANDALORIAN
Las Vegas
2019 JLU SPORT
Yes it is CF. Dual friction at the time it was the only aftermarket for for the JL
Mandalorian
Mandalorian
MANDALORIAN
Las Vegas
2019 JLU SPORT
Good luck
Agreed. Their own website doesn’t even give a description. I purchased the CF clutch from summit racing. They said they could have it to me in 1-3 days?
