CB Radio Install
matchews
Chagrin Falls, Ohio
JLU
I just installed a Uniden Bearcat CMX760 under the passenger seat. Wanted to share a few things I learned. First off, there are three ground lugs, one completely unused behind the passenger front right kick panel. They are right below the front right door wiring harness, which is removed in this picture. I used the lowest one for the CB.
Jeep Wrangler JL CB Radio Install 79845271-9C93-4DA8-BB48-19095115DF37
The font passenger sill/kick cover snaps off by pushing horizontally toward the center of the vehicle.
Jeep Wrangler JL CB Radio Install F8088943-58FE-4354-BC16-E9F013456655
Jeep Wrangler JL CB Radio Install 2B99EB5F-AAAF-47AD-8957-AADB026812A7
Jeep Wrangler JL CB Radio Install B1338BCF-0A5E-4449-A858-B5607B40B02A
Here is the radio mounted under the passenger seat. There was a ground lug I used to mount the Uniden bracket. I only used the one fastener, but it feels solid.
Jeep Wrangler JL CB Radio Install D6965CB8-063F-4879-8C44-30D1F3F2840D
I zip tied the CB wiring to the wire loop that runs under the carpet and allows the seat to articulate fore/aft when adjusted.
The antenna will be mounted in the the tailgate reinforcement bracket. The fire ring cable had an intermittent ground, so I’m waiting on a replacement cable to finish that up. I removed the paint on the bottom surface and also pulled out a hinge bolt, removed the plastic washer, removed some paint and added a star washer for a good ground to the tailgate reinforcement bracket. I will also run a ground strap from the backside of that fastener, through the tailgate wire loom and to a good ground in the rear right side. I still need to remove that plastic to run the coax and attach the ground strap. I hope this helps someone!
Jeep Wrangler JL CB Radio Install 1452FCF8-B8FF-4953-BC98-39F51849BC41
Jeep Wrangler JL CB Radio Install 28BDF748-83AC-41AB-802C-2E20AB6AEA03
Jeep Wrangler JL CB Radio Install 5A7FF75B-587A-4C17-AEB5-33B51A31727B
macintux
Indianapolis, IN
2005 LJR, 2022 JLR
Nice work, thanks for sharing. I’ve been wary of underseat mounting on my LJ because the top is off all summer including during heavy rain, but that looks far enough off the floor there shouldn’t be a problem. Will have to take another look at mine.
Manno
Clarksville TN
2013 Tacoma
US Army
Thanks for the information! Please keep us posted once its wired up. I'm always worried about removing paint but what you described seems reasonable
matchews
Chagrin Falls, Ohio
JLU
Here are some more pictures...
There is one small screw to remove on the right rear cargo trim. It’s right behind the right rear seat.
Jeep Wrangler JL CB Radio Install FA9365C0-2F81-4B62-A972-740E7F54445A
Jeep Wrangler JL CB Radio Install 1357BF81-AB4C-4B73-AEC3-32C2CB967810
Jeep Wrangler JL CB Radio Install 6F3E5705-7900-4B8A-9D44-8D25B3F2842B
Jeep Wrangler JL CB Radio Install 467A31C3-1032-49DD-BDE5-77D4EFBCECEB
Jeep Wrangler JL CB Radio Install 2BFAAF04-19D2-4173-8CBE-139AA629080D
Jeep Wrangler JL CB Radio Install 2CA9F336-068E-4050-9CB6-F8CF5552ACD6
desert runner
Peter
Fort Collins Colorado
JLUR MetalCloak 2.5F/3.5R, LoD Bumper/Carrier.
I discovered this thread as I am planning to install my CB radio.
Matt, wondering how you tabbed into 12V. Were you able to tab such that you only have power with ignition on?
YOKiN
Jason
'65 Impala SS, BMW X5M, 2018 Wrangler JLUR
Military
@matchews would you happen to know what Antenna stud you used to fit in the hole of the Reinforced bracket? The part I have seems to be too large of a diameter to fit through.
matchews
Chagrin Falls, Ohio
JLU
Fire ring with a longer stainless steel bolt
matchews
Chagrin Falls, Ohio
JLU
I used accessory wire bundled with the aux switch wiring.
YOKiN
Jason
Military
@matchews I think I'm going to finally install my antenna on my tailgate reinforcement bracket as well tomorrow. Was it pretty easy to remove some paint from the bottom? Also, I'm mostly worried about making sure it's properly grounded. (Opposite of the interior portion), where did you place the other end of the grounding strap?
matchews
Chagrin Falls, Ohio
JLU
I just sanded the paint away. A star washer would help as well.The ground strap, which should be as short as possible, was ran through the tailgate wire loom up to the rear corner where I removed some paint and placed it under a mounting bracket for an electronic module. I had already removed the rear subwoofer and surrounding plastic trim, so this was easily accessible.
desert runner
Peter
Thanks Mathew, I followed your instructions, however, decided to instal the radio under the glovebox.
Jeep Wrangler JL CB Radio Install BA2611E0-ECDF-4069-93F0-EF247BBAAC8D
YOKiN
Jason
Military
Oh so on the exterior side you had the other end just directly in contact with the sanded portion of the tailgate?
HardRock
Beverly Hills, CA
2015 Rubicon JK Hard Rock Edition (FL); 2018 Rubicon JL (CA)
Great post - I am getting the same radio. Did you ever consider mounting it in the console? Does the handset reach all the way to the driver's side?
DanW
Nice! I'd love to see a couple more pics of this location. Thanks!
desert runner
Peter
I found a screw tying down a cable for one side, the other side is zip tied to the air vent. Power and antenna cable to the right, microphone extension to the left.
Jeep Wrangler JL CB Radio Install CDC73CCE-5B70-46FE-963D-FA5EE34BEC97
