CB Antenna Mount Needed!
desert runner
Peter
Fort Collins Colorado
JLUR MetalCloak 2.5F/3.5R, LoD Bumper/Carrier.
I’m no expert but isn’t a properly tuned cb based upon certain wire and antenna length? Something to do with the length of the radio waves?
Also regarding the ground plane talk above, couldn’t you apply an appropriate ground strap from that mount to the chassis/frame ground to achieve proper grounding?
Antenna cables come in different lengths, what counts is the length of the antenna itself.
desert runner
Peter
the cover is plastic plus i have cube lights mounted there
So maybe you have something like this installed? The bracket I am proposing could be mounted right on top of it. Of course, alternatively you could use a standard antenna L bracket and attach it to this light mount.
Jeep Wrangler JL CB Antenna Mount Needed! upload_2018-4-25_17-24-9
The fact that the cover below is plastic may be irrelevant, as long as the bracket is grounded via the bolts.
DickZip
S/w Florida
2018 Jeep Jl Rubicon
Jeep Wrangler JL CB Antenna Mount Needed! IMG_3216
I think it could work, but not for me. I don't think that location is strong enough because of the plastic cowling. I bet it would be easy to damage.
desert runner
Peter
Until we have more aftermarket antenna mount choices for the JL, here is my solution.
A 15” trucker rubber duck antenna hidden behind the canvas.
Good enough to communicate in close proximity, which is mostly what I need it for.
Jeep Wrangler JL CB Antenna Mount Needed! FC4EF20D-C95B-4C67-8AB0-16BA54537E92
DanW
DanW
What if you took this pair of light mounts and mounted them on the accessory bolts on the side of the cowling, then fabricated a metal bracket that attached to these, with an antenna mount on them. Then you could run your CB antenna right next to the A-pillar, which seems to be a good spot for the Jeep?
It woldn't be too different from that light mount above, but it would still allow for folding the windshield.
http://www.aceengineeringandfab.com/ACE-JL-Cube-Risers_p_256.html
desert runner
Peter
I think you described my proposal above in different words :) - I agree, this would be the way to go.
DanW
DanW
Yeah, I think you are right. I think the location would be good for both sight line and for reception/transmission.
I can't believe nobody has gotten to market yet with a decent CB antenna mount, whether where you suggested, or for the tailgate or spare tire carrier. Hopefully, we'll get a bunch of options all at once, and soon!
PaPasJP
Gainesville, FL
I decided to make my own, usually not a good thing,
I went to my welding/manufacturing shop I use and told them what I wanted.
This is what we came up with:
Jeep Wrangler JL CB Antenna Mount Needed! 1UqCVH5yAfk1oR9QaYzbwmxB8ko0j7Q3ACxqqMvCRBVsibzl_bEFQFjEGk9agqZUKB9Tt1JXf1ftBSj1gBE=w459-h258
Jeep Wrangler JL CB Antenna Mount Needed! M6fgO5xVqdKYTbaA4RE6f9I_CDtjOj0viL3-6-MvDv4pVV03aiFfJjQi3ZMPAWTwX3iwv9OqDZsmkJG8u5c=w534-h949-no
Jeep Wrangler JL CB Antenna Mount Needed! A5tzysVrG5c7_QCSlyG6eNXYBZvHCvSYHBxzJ8bPgKLgk4X4tJUVvObBHX6oinvQKuIak1p903RDGPnK3PA=w534-h949-no
I had it powder coated to match the red accents of the Rubicon.
It grounds to the tailgate so an easy mount.
It looks good and has room for my 37's when I jump.......... LOL
AZCrawl
AZ
2018 Granite Jeep JLUR
1UqCVH5yAfk1oR9QaYzbwmxB8ko0j7Q3ACxqqMvCRBVsibzl_bEFQFjEGk9agqZUKB9Tt1JXf1ftBSj1gBE=w459-h258...webp
M6fgO5xVqdKYTbaA4RE6f9I_CDtjOj0viL3-6-MvDv4pVV03aiFfJjQi3ZMPAWTwX3iwv9OqDZsmkJG8u5c=w534-h949-no.jpg
A5tzysVrG5c7_QCSlyG6eNXYBZvHCvSYHBxzJ8bPgKLgk4X4tJUVvObBHX6oinvQKuIak1p903RDGPnK3PA=w534-h949-no.jpg
Looks good. I wonder if it will still work with the tailgate reinforcement kit?
CoolTech
Rock Sponsor (Level 1)
Kendall
Santa Clarita, CA
2018 Rubicon
Our Cool Tech JL-specific Antenna Kit is now in-stock and available for ordering and immediate shipment. The bracket has a unique JL-design and is intended to complement some of the creative "tells" that Jeep has incorporated throughout the JL. (Has anyone else noticed the camo pattern at the bottom of the interior door grab handles?) The bracket is stainless steel as it the mounting hardware. The kit is available with either a 3' or 4' Firestik Firefly antenna. This is a very nice antenna for this mount. Here's a pic of the kit contents (sans the antenna).
Jeep Wrangler JL CB Antenna Mount Needed! jl-cb-antenna-kit
Additional pictures, description, and ordering information can be found here: http://www.cooltechllc.com/wrangler-parts-accessories/109-jl-cb-antenna-kit.html
TroyBoy
Troy
Vancouver Island, Canada
Actually it is easy to attach a wire from the back side of one of those bolts(remove the inside large plastic cover to get access) then run that wire to the jeep and ground it.
Bearded_Dragon
FL
2018 Mojito! Rubicon
I'm not following, isn't the tailgate magnesium? Couldn't we add a grounding strap from the body to the tailgate for a good ground? I'm assuming there's some type of rubber/plastic/delerin bushing on the tailgate hinges.
DanW
DanW
Nice mount and kit, but man, that's a little bit expensive! I'm still exploring my own solution using the two accessory bolts on the driver's side of the cowling. If it works well, my brother and I might make them and sell them. We shall see!
usmcss
Bob
Illinois
Black 2018 Rubicon JL
Will anything have to be done to ground this mount for the antenna or are the bolt and bolt holes good enough? Thank you!
PaPasJP
Gainesville, FL
I get a great ground through these bolts with the one I made, so this should be the same.
