Can't find the current speaker specs
Gaust
Todd
Portland, Oregon
2018 Wrangler JLU Rubicon, 2018 Renegade Trailhawk
From my understanding the OEM, non Alpine, amp is an 8 channel amplifier with built in audio processing. There is a set of 4” and 3.5”, maybe 2”, in the front and sound bar. The 4” is in a ported enclosure and has a low pass filter to cut out most of the mid and all the high range. The smaller speaker has a high pass filter that cuts out most of the bass. I don’t believe the 4” has a crossover on the low end, cutting out the bass. You could add a “bass blocker” capacitor if you were going to use the OEM speakers.
Cutterone
NH
2025 Willys 4dr 2L Firecracker
Gonna use the speakers for now but cross them over from the sub, or use a bassblocker if needed
Gaust
Todd
Portland, Oregon
I just pulled the OEM dash speaker. It’s 8 Ohms and 15 Watts. The hole in the dash is 80mm in diameter.
