RavenJeep
So here is my take, wait and order the new Moab special edition that has been confirmed to be coming out. It will hit all your needs. Looks more like a rubicon with steel bumpers and the Rubi hood and rock rails, will likely have the upgraded Rubi back axle, will have Sahara interior and be available with Select trac for NE winters. It should tick all your boxes, be priced higher then a non equipped Sahara but lower then a Rubi if previous history holds. I had the same dilemma, pulled the trigger for a Mojito Rubi because I wanted the exterior, slight lift, bigger tires, and axles for towing our camper and I fell in love with the Mojito color which is not supposed to be available 2019 but now I’m second guessing it. Like you, in the NE, mostly beach wheeling, tow a 2800 lb camper and some off roaming but nothing my upgraded Sahara couldn’t handle.
