Can an electrical guru help?
DonH63
Don
Monument, CO
21 GC Trailhawk, 23 JLU 392 XR
Retired EE; musician (trumpet)
p.s. Motors/compressors tend to have very high initial starting current spikes that could damage the converter.
Still think... you know!
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
As a guess, assuming the wires in your diagram are going to the compressor, and assuming the smaller wire is for control circuits so not a heavy load, then you could try connecting BLK-WHT to ground, BLK to the positive terminal of your 12 V battery, and RED to the 24 V output of your converter. Then pray nothing gets grounded or shorted along the way. Read the instructions carefully; you may need to isolate the compressor.
If it is an ARB compressor, why not ask them?
Still think getting the correct compressor will save you grief.
It looks like the only 12V connections are the pressure switch, relay, and switch. May be able to confirm ratings and swap (if necessary) for 24V rated devices.
GATORB8
CLT NC
GATORB8
CLT NC
https://www.amazon.com/Cllena-Conve...fos.f5122f16-c3e8-4386-bf32-63e904010ad0&th=1
There is the potential that you could run two of the smaller converters in parallel, I'm not thinking of a reason it wouldn't work.
These are fairly simple devices, but not sure I'd hook them to a $600 compressor. I have a 48-12 step down in my golf cart for the audio system from the same factory in China, not super confidence inspiring quality.
danba
danba
Johnny
Southwest
Tncdrew
Tom
East Tennessee
2022 JL Willys, 3.6L - 8spd
Why would you have ever gone in this direction to start with?
Why add more components and complexity for such an otherwise simple straightforward installation?
Maybe I'm missing something here... ?
CaJLMetalHead
CAJLMetalHead
Jeep Wrangler Sport Unlimited
Looking into the details of the compressor versions I noticed that the 12v and 24v versions have Relays and fans that are specific to the voltage... as noted by note number 4 in the first page of this document:
https://www.arb.com.au/assets/air-lockers/3-07.pdf
Jeep Wrangler JL Can an electrical guru help? 1704326922462
That means you need to get (from image above):
10(a) Compressor Assembly (12V) Part number: CKM01
20(a) Cover Assembly, CKMTP12 Part number: 320109
I found the Compressor assembly for sale... but not the
Cover Assembly... I guess one option is to disassemble it
and replace the relays and fan with 12v versions
https://www.polyperformance.com/arb...K3HMt2QiWLSqV_gW0vrf7xQq0py_9wIBoCdlMQAvD_BwE
Part are highlighted on image below:
Jeep Wrangler JL Can an electrical guru help? 1704327113929
GATORB8
CLT NC
Good catch. The footnote has the relay and fan part numbers in it. Looks like the relay is pretty common online.
danba
danba
Johnny
Southwest
The bad news is that item 10 is only ONE of the two motors. Per ARB's email I need x2.
My bargain 24v compressor is no longer a bargain :(
GATORB8
CLT NC
Be cheaper to just order the Rough County clone and swap the compressors in.
Or run the RC one and sell the ARB if you can’t return it.
DonH63
Don
Monument, CO
Expensive mistake, expensive learning experience, welcome to the World of Jeeps...
CaJLMetalHead
CAJLMetalHead
For future reference I would like to know what you meant with "My bargain 24v compressor is no longer a bargain".. was this a one time deal? links? shady offers? we would like to know as to not make the same costly mistakes.... Thanks!
danba
danba
Johnny
Southwest
It was a black Friday deal. I selected the 24v by mistake and didn’t realized it until it was too late to return. User error.
