Can an electrical guru help?
danba
Johnny
Southwest
I bought a 24V compressor instead of a 12V. I'll be using a 12V to 24 transformer to feed it proper voltage. However I'm confused by this ARB diagram:
Jeep Wrangler JL Can an electrical guru help? 1704317523289
Why is the BLK wire going to the Battery 2 Negative? Can I just connect both the BLK and the BLK-WHT on my ARB compressor to the 24V+ and 24V- cables on my transformer?
BTW, this is the convertor: https://www.amazon.com/dp/B09YY715Q1
Thanks!
Yawnie'sPapa
Bill
Central Iowa
'22 JTO, '23 JLUR, '82 SX4, '73 P. Cardin Javelin
Thanks!
How are you going to use a transformer on DC current?
Transformers - a true transformer, can only work with non-DC power.
Looking at the ARB diagram also tells me - it isn't going to fly.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Thanks!
It's running dual voltage. Something is on 12V and something is on 24V
That converter is not big enough.
danba
danba
Johnny
Southwest
Thanks!
The convertor is 20A@24V, the way I read it at least. That is more than the ARB is rated at max 24V draw (forgot the number, but I know I've checked it. I think it's 16A).
Please correct me if I'm wrong.
As far as the dual voltage, does it mean that I can feed it 24V from 12V from the battery?!? Can't be! That would require two separate positive (+) feeds.
I need to follow the diagram - the 12V might only feed the lamps on the switches.
GATORB8
CLT NC
14 amps is no load (half of the 12V no load), under load would be 25 amps (half of the 12 V load). Plus some voltage loss headroom.
No, in a system with dual 12 V batteries, you can draw either 12 or 24 V. in a system with a single 12V battery, you can only draw 12V. In this case, one circuit is drawing 12 V (the one with the small ground) and one circuit is drawing 24V (the one with the big ground).
danba
danba
Johnny
Southwest
My liberty in using improper terms, like transformer instead of up converter, shows my "knowledge" of electrical devices :) .
Santana74
Jamie
Alabama
23 Wrangler Sahara Altitude 3.0l, 18 Jaguar F-Pace
Voltage is added in series and constant in parallel (might be worded weird). Negative term connected to Positive term is putting two 12v batteries in series, 24v.
A stock Jeep has 2 batteries. You could put these in series and see if the amps are enough to run the compressor. Don't blame me if you blow your Jeep up, it was only an idea. JK
GATORB8
CLT NC
The two batteries in the ESS Jeeps are already wired in parallel, can't just add a series connection, you'd be grounding a positive terminal.
DonH63
Don
Monument, CO
21 GC Trailhawk, 23 JLU 392 XR
Retired EE; musician (trumpet)
As a guess, assuming the wires in your diagram are going to the compressor, and assuming the smaller wire is for control circuits so not a heavy load, then you could try connecting BLK-WHT to ground, BLK to the positive terminal of your 12 V battery, and RED to the 24 V output of your converter. Then pray nothing gets grounded or shorted along the way. Read the instructions carefully; you may need to isolate the compressor.
If it is an ARB compressor, why not ask them?
Still think getting the correct compressor will save you grief.
GATORB8
CLT NC
danba
danba
Johnny
Southwest
I have a 392 which only has one battery.
Note, the compressor can exceed the "load" rating significantly, max is 34.3 amps @ 24V:
https://www.arb.com.au/assets/air-lockers/6-07.pdf
Correct. I also seem to lack reading comprehension: not only did I misread the compressor voltage, but also this convertor's ratings:
  • Output Voltage: 24V(Fixed Output), Output Current:20A, Output Power:480W, High Conversion Efficiency: up to 97%
Geez!
danba
danba
Johnny
Southwest
DonH63
Don
Monument, CO
Note the OP has a 392, so no ESS, and only one (12 V) battery.
